20 Most Recent Cub Cadet Lawn Mower V belt Replaces CUB CADET 9543038 Questions & Answers
Cub cadet lt 1022
Some of these belts cost around $40
7/24/2014 4:15:59 AM • Cub Cadet Lawn... • Answered on Jul 24, 2014
Cub cadet 1000 series LTX 1040 riding lawn mower
Check the pully alignments with a straight edge. Make sure the belt is tight.
5/19/2013 11:16:34 PM • Cub Cadet Lawn... • Answered on May 19, 2013
How do I reset the clean air filter warning on my cub cadet LT42
It's a 50 hour service reminder that will auto reset after 7 minutes (engine running).
3/14/2024 5:03:29 AM • Cub Cadet Garden • Answered on Mar 14, 2024
Cub Cadet 1050 2014 model. The gas pedal locks in the down position until engaging the break.
If the gas pedal on your 2014 Cub Cadet 1050 model is locking in the down position until the brake is engaged, there may be an issue with the mower's safety interlock system. This system is designed to prevent accidental engagement of the blades when the operator is not in control. Check for any debris or obstructions around the pedal mechanism and the brake system. Additionally, inspect the safety interlock switches near the brake pedal for proper function. If the issue persists, it's recommended to consult the owner's manual for troubleshooting steps or seek assistance from a qualified Cub Cadet service professional to ensure safe and proper operation.
1/28/2024 11:39:47 AM • Cub Cadet Garden • Answered on Jan 28, 2024
Cub cadet chipper shredder starter coil is locked - will not pull
Recoil starter is locked?Remove spark plug to be sure engine hasn't hydrolocked with fuel and/or check crankcase oil level. If excessively high oil level then likely crankcase and cylinder is full of fuel from a stuck carburetor fuel inlet needle valve.If cylinder is clear of fuel/oil then remove recoil starter and see if recoil is functional and engine will rotate by hand.
12/6/2023 8:03:07 PM • Cub Cadet Garden • Answered on Dec 06, 2023
Need wiring diagram for cub cadet mod 13bx11cg712
https://www.ccpartsnmore.com/uploaded/files/cub-wire-schematics/cub-lt-tractor-wiring/LT%201042%20%282005%29.pdf
11/29/2023 12:17:27 AM • Cub Cadet Garden • Answered on Nov 29, 2023
Cub cadet lxt 1046 throttle cable how to change
For the most accurate and up-to-date information, I recommend consulting the official Cub Cadet LXT 1046 operator's manual. The manual typically includes detailed instructions on maintenance procedures, including how to replace components like the throttle cable.
11/15/2023 2:05:46 PM • Cub Cadet Garden • Answered on Nov 15, 2023
I need a size replacement belt number cub cadet deck belt
Hey, I gave you all this information yesterday! The answer doesn't change because it is a different day. Stop hiding behind 'Anonymous', it is hardly a secretive post! https://www.fixya.com/support/t29936480-size_belt_replacement_sears_2000_cub The SV 590 is the model designation of the Kohler engine powering the lawn tractor. https://www.google.com/search?q=kohler+model+sv590s+parts+diagram The 'Sears 2000 Cub Cadet' part is most of your tractor model details and the Deck Belt appears to be 42". https://www.google.com/search?q=Sears+2000+Cub+Cadet+deck+belt ..
10/15/2023 2:27:18 AM • Cub Cadet Garden • Answered on Oct 15, 2023
2answers
What size belt replacement for Sears 2000 Cub Cadet deck belt model SV 590?
10/14/2023 3:28:00 AM • Cub Cadet Garden • Answered on Oct 14, 2023
Cub cadet hydro 1320 starts but won't stay running longer than a few minutes. Fuel is good?
i dont know nothing about the cub cadet but if its doing that i would change the camshaft positioning sensor
9/6/2023 9:56:15 PM • Cub Cadet Garden • Answered on Sep 06, 2023
Cub Cadet with Onan 14hp . PTO clutch and PTO engagement switch both new. PTO clutch disengages whenever it wants. Cold or hot. Charging system issues? How to info check and what to look for?
The clutch likely has an adjustable air gap that requires adjustment. The procedure will be outlined in the model service manual. Typical gap is 0.015"
8/29/2023 8:15:32 PM • Cub Cadet Garden • Answered on Aug 29, 2023
20 amp fuse keeps blowing when engaging PTO, cub cadet ZT1 54 (model 17AREACA010)
Disconnect the voltage regulator and replace the fuse. If the fuse doesn't blow then likely the regulator was damaged and will need replaced.
8/29/2023 10:32:09 AM • Cub Cadet Garden • Answered on Aug 29, 2023
We have a 1986 Cub Cadet Hydro 1210 that won't go forward!
If your 1986 Cub Cadet Hydro 1210 is experiencing difficulty moving forward but works fine in reverse even after changing the transmission filter and fluid, there could be a few potential reasons for this issue. Here are some steps you can take to troubleshoot the problem: 1. **Check Drive Belt:** The drive belt is responsible for transferring power from the engine to the transmission. A worn or damaged drive belt can affect forward movement. Inspect the drive belt for any signs of wear, fraying, or damage. If the belt is in poor condition, consider replacing it. 2. **Check Tension of Drive Belt:** Ensure that the drive belt is properly tensioned. A loose drive belt can lead to slipping and difficulty in forward movement. Adjust the tension according to the manufacturer's specifications. 3. **Inspect Linkage and Connections:** Examine the linkage and connections between the control lever, transmission, and the drive system. Loose or misaligned linkage can result in improper engagement of gears, affecting forward movement. 4. **Hydrostatic Transmission Issues:** Since your Cub Cadet Hydro 1210 uses a hydrostatic transmission, there could be issues with the hydrostatic unit itself. Check for any signs of leaks, damaged hoses, or worn components in the hydrostatic transmission system. 5. **Transmission Oil Level and Quality:** Ensure that the transmission oil level is correct and that you're using the recommended type of oil. Poor-quality or incorrect transmission oil can lead to performance issues. 6. **Air in the Hydraulic System:** If there's air trapped in the hydraulic system, it can cause issues with the hydrostatic transmission. Bleed the hydraulic system to remove any air bubbles. 7. **Transmission Pulley and Sheaves:** Check the transmission pulley and sheaves for wear or damage. If these components are not functioning properly, they can affect the movement of the drive belt. 8. **Check for Obstructions:** Inspect the underside of the mower deck and the drive system for any debris, obstructions, or objects that might be interfering with the forward movement. 9. **Professional Inspection:** If none of the above steps resolve the issue, it might be a more complex problem requiring the expertise of a professional technician. They can perform a more in-depth diagnosis of the hydrostatic transmission system and identify any underlying issues. Keep in mind that working with mechanical and hydraulic systems requires knowledge and expertise. If you're not comfortable performing these checks and repairs yourself, it's recommended to consult a qualified technician who has experience with Cub Cadet or similar equipment.
8/26/2023 10:16:07 AM • Cub Cadet Garden • Answered on Aug 26, 2023
Cub Cadet RZT-L 42 Zero Turn Mower. Right turn lever is binding/sticking on my mower. How do I loosen it so it returns to neutral on its own?
Lubricate all the linkages with spray lubricant.
Cub Cadet RZT L 42 Operator's Manual [Page 22]
ManualsLib https://www.manualslib.com > ... > Operator's manual Refer to the Engine Manual for all engine maintenance intervals,. procedures, specifications and instructions. Lubrication. •. Using a pressure lubricating gun, ...
8/10/2023 4:37:00 PM • Cub Cadet Garden • Answered on Aug 10, 2023
Cub cadet blowing fuses when engaging the PTO. LT1554 starts and runs until engaging the blades.
If it is blowing fuses my experience is you have a short in a switch or wires. When you put in the pto it blows the fuse. That would lead me to think the electrical short has something to do with the PTO safety switch, wire or circuit.. I am posting this link it is not your tractor but it demonstrates the safety switches on lawn tractor and shows his pto safety switch. Your issue should be in the pto safety switch or wiring circuit. Might be something like cut or wire with insulation stripped back touching a ground. Switch could be shorted.
8/3/2023 11:17:54 PM • Cub Cadet Garden • Answered on Aug 03, 2023
4answers
Sprayed water from garden hose to clean off deck only. Mower will crank over but not start. Cub Cadet LTX1042
You got water in the electrics. It is the spark that is the issue not the spark PLUG, fuel and carburetor. Leave it outside in the sun for a day or in the garage for a week and it will dry out. Or WaterDisplacement(formula)40 is a great product if you can find where the electrics got wet.
8/1/2023 8:25:43 AM • Cub Cadet Garden • Answered on Aug 01, 2023
2answers
While, mowing 50 inch cub cadet tank, zero turn just lost all power and will not start
Check battery voltage is over 12.0 VDC and fuse is intact.The unit requires Brake ON, PTO OFF, and both steering arms out (neutral) to crank. Cycle the components Brake, PTO, and steering arms and try again.There are no relays, just switches. The wiring diagram is in the operators manual available no fee download from multiple sources including CubCadet. Some alternative part suppliers include the wiring diagram in the parts list.https://www.cubcadet.com/en_US/operatorsmanuals
7/5/2023 4:26:18 PM • Cub Cadet Garden • Answered on Jul 05, 2023
M60 cub cadet zero turn. What causes it to shut off?
There is also a safety switch for each of control arms, they both have to be in the neutral position. You may have to adjust the arms. Are you checking the resistance at the switches?
7/5/2023 12:14:18 PM • Cub Cadet Garden • Answered on Jul 05, 2023
Cub Cadet Lawn Mower V belt Replaces CUB CADET 9543038 Logo
4 questions posted
Top Cub Cadet Garden Experts
john h
Steve Sweetleaf
Steve Sweetleaf
Daniel Blask
Daniel Blask
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
View Most Popular
Cub Cadet Garden
  • Cub Cadet Garden
Most Popular Question
cub cadet lt 1022
  • Garden
