20 Most Recent
Schwinn High Timber Girls' Mountain Bike (24Inch Wheels) Questions & Answers
What is the shape of the handle bars on the Schwinn High Timber Girl's bike?
These are certainly not racing style bars; but the modern, hybrid riser handlebar. They will not sweep back toward the rider as much as a beach cruiser handlebar; but could be adjusted rearward to come closer to the rider. They definitely allow for a more upright riding position than many other handlebars though.
How do I fix the grip shift ? The piece that you
on the top of your grip shift there will be a slot for your shifter cable to connect. there should be a bolt there as a tensioner as well as on shifter itself. these may have to be tightened because it sounds as if they are loose.
What is the wheel circumference of older 1988 AirDyne to use for bike computer to replace Schwinn ergometer?
The wheel circumference of a 1988 Schwinn AirDyne exercise bike may vary depending on the specific model and tire size. To determine the wheel circumference for your bike computer, you'll need to measure it directly. Here's how you can do it:
- Measure the Tire Diameter: Lift the front wheel of the bike off the ground so it's freely spinning. Use a tape measure to measure the diameter of the tire from one side to the other. Make sure you measure the actual tire, not the rim.
- Calculate the Circumference: Once you have the diameter in millimeters, you can calculate the circumference using the formula: Circumference (mm) = ? (pi) x Diameter (mm).
- You can approximate ? as 3.14 for simplicity.
- Convert to Centimeters or Meters: To make it more compatible with most bike computers, you might want to convert the circumference from millimeters to centimeters or meters.
