20 Most Recent
Proform 680 LT Treadmill Questions & Answers
Belt problem ...
Hi Paula, I know nothing about it, you could lift the belt and use DW40 or vegi spray where it's squeaking. Nothing beats a walk in the park. Greg.
Need a new safety key
The treadmill has inclined and will not retract. We think a reset is needed but not sure how to do it.
Oil on treadmill surface
you must test if the machine use WAX, test for leak pump ,clamp,etc2) See if the material from deck belt is causing this, because is normal that some material white is coming from this.God bless you
Button doesnt work for speed 6
Dear Sir:Please readjut the reed switch see the diagram and run the software calibration for easy diagnose and troubleshooting. sincerely. God bless you.ernesto cuadramanagua, nicaragua. c.a
Treadmill
Dear Sir:Please adjust the reed switch, according with the diagram attached 1/8-1/4". 2) Tight the ribbon cable from keypanel (display board) 3) Tight the connector from display board vs main motor board.Run the software calibration for reasy diagnose and troubleshooting.See my block diagram for better undertanding. sincerely.God bless you. ernesto cuadramanagua, nicaragua. c.a.
Display panel is not working. It will come on in demo mode but none of the buttons work
Dear Sir:Adjust the reed switch, by 1/8-1/4 see the diagram attached. 2) Tight the ribbon cables from keypanel 3) Tight the connector from display board vs main motor board.Run the software calibration for easy diagnose and troubleshooting.See my personal block diagram for easy understanding in troubleshooting. sincerely. God bless you.ernesto cuadramanagua, nicaragua. c.a
Treadmill track stops
Dear Sir:This a common problem.The main reason is worn belt in the deck. The electronic control every movement from the treadmill.When the time, the worn cause many friction between belt vs deck, and the electronic design help the machine to shut down.... The reason for friction Enough is for lack of maintenance, specific for Lubricanting.See the block diagram that I did for easy troubleshooting.
sincerely. God bless you.ernesto a cuadramanagua, nicaragua. c.a.
How to adjust the volume on proform 680 lt
http://www.iconservice.com/CustomerService/manualsProductManuals.do?model=PFTL96008&modelName=PROFORM+680+Please go to that web page and download your user manual free.and then read carefully the page 18-19 in how to adjust the volume.sincerely.E.CUADRAMANAGUA,NICARAGUA
