20 Most Recent Bowflex SelectTech 552 Dumbbell Pair Redesigned for 2009! Questions & Answers
I need a weight from
Here are parts lists for the SelectTech 552 Version 1 and the SelectTech 552 Version 2. Looks like some weights are not available but some of them are, depending on which version is yours I hope the one you need is available.
5/4/2011 8:49:20 PM • Bowflex... • Answered on May 04, 2011
I keep getting error code 0AB
Error code 0AB on a Fisher & Paykel refrigerator may indicate a problem with the evaporator temperature sensor. The evaporator temperature sensor is responsible for monitoring the temperature inside the freezer compartment. If the sensor is not functioning properly, it may send incorrect temperature readings to the control board, causing the error code to appear. Some possible causes of this error code include:
  • The evaporator temperature sensor is malfunctioning and needs to be replaced.
  • The wiring connections between the sensor and the control board are loose or damaged.
  • The control board itself is malfunctioning.
If you are seeing this error code, I would recommend checking the wiring connections and the sensor and if they are ok then the control board may need to be replaced. It is best to contact a qualified technician or the manufacturer for help troubleshooting and repairing the issue, as working on refrigeration equipment can be dangerous if you are not properly trained and equipped.
1/29/2023 8:03:23 PM • Bowflex Exercise... • Answered on Jan 29, 2023
Bowflex TC100 Treadclimber Speed Up/Down buttons don't work
remove and replace console bezel assembly. screen shot 2022-11-18 at 4.10.16 pm-undefined-undefined-0.png
11/18/2022 10:14:25 PM • Bowflex Exercise... • Answered on Nov 18, 2022
2answers
How can I repair of bowflex series 7, The controller board seems to be broken
contact Bowflex this is not bowflex tech support
5/22/2021 5:49:00 PM • Bowflex Exercise... • Answered on May 22, 2021
2answers
How do I fix L5 error on a Bowflex TreadClimber tc3000
If you wish to get some details; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
8/21/2020 3:14:28 PM • Bowflex Exercise... • Answered on Aug 21, 2020
My question was about the bowflex ct5000 step climber piston shocks leaking why?
The hydraulic shocks found on exercise machines aren't very different to the shocks found on cars, bikes and trucks or even inside some washing machines - the ones on display on bikes and exercise machines are better finished and nicer to look at. Your question is asked everyday by thousands of vehicle owners who also want to know why shocks leak. I have a theory, but it is just a theory - If a telescopic shock absorber is going to leak they mostly start leaking while relatively young. I think very few leak because the seal is worn out - a very few do and that happens after a long service life. I think in some cases it could be the quality of the seal or the way it is fitted but my theory is about the ambient temperature, the temperature of the components and the temperature of the oil that fills the shock. It is possible during manufacture a certain volume (rather than a weight) of oil is placed in each shock and at certain times, such as first thing after the weekend, in the winter perhaps, the oil will be cold so when the finished item meets hot weather the fluid expands and the level could rise enough to overwhelm the seal...
6/29/2020 4:00:26 AM • Bowflex Exercise... • Answered on Jun 29, 2020
Bowflex tc5500 circuit board error code D status R23 red
www.treadmillpartszone.com You must locate to side from the power switch you must find the fuse holder and replace the fuse with THE SAME SIZE+CAPACITY+VOLTAGE INDICATED FROM THE SAME FUSE. Remember if the fuse is Blown again or continuing you have a short circuite in a) Transformer b) Main Motor c) Main Controller Board d) Faulty ground in your receptacel from the wall very carefully. attached the block diagram that I did for to illustrate to person like you, good luck. sincerely.
6/22/2020 4:20:30 PM • Bowflex Exercise... • Answered on Jun 22, 2020
Cant find calibration button Bowflex TC5000
Hi. Please click on the link to view how to calibrate the treadmill. https://www.manualsdir.com/manuals/58333/bowflex-treadclimber-5000-treadclimber-3000-treadclimber-1000.html?page=33 Kind regards.
4/7/2020 11:37:47 PM • Bowflex Exercise... • Answered on Apr 07, 2020
Checking speed sensor on series 7 bowflex treadmill
Bowflex company is alive and kicking, did you try calling them for the best information? Don't let them try to sell you a new machine unless they give you a great big discount, ask about repair.
11/2/2019 6:33:38 PM • Bowflex Exercise... • Answered on Nov 02, 2019
Bowflex series 7 treadmill. getting LS error. Replaced speed sensor, calibration is able to complete. if I try to run a program LS error returns and belt wont turn. Can work w/o using programs
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. Check for treadmill articles http://electro-medical.blogspot.com/
10/14/2019 4:38:12 PM • Bowflex Exercise... • Answered on Oct 14, 2019
BowFlex Ultimate 2 machine second-hand. Resistance rods do not provide enough resistance.
you should be able to then by turning the caps on the top of them
9/26/2019 8:49:08 PM • Bowflex Exercise... • Answered on Sep 26, 2019
I have a Nautilus Treadclimber TC5000. I believe it is the same as the Bowflex machines. How do I change out the rear roller assembly from the two rear rollers it has to the single roller replacement? Do I need the rear drive plate, as well as one of the Igus washer and bearing middle system and two rear inner brackets? Will that fit and work for my tc5000 version1? Thanks for your help!
did you need help finding the manual? All we would do is access the manufactures website search for your item and obtain the manual- after we would furnish you the results as per the manufacture. Most companies do not support comparable parts only authorized- How can I get this question closed? What can I provide you? good luck https://www.6ya.com/mrmmike
3/2/2019 11:51:47 PM • Bowflex Exercise... • Answered on Mar 02, 2019
Bowflex Treadclimber TX10 safety switch is broken and there are no replacement how do I bypass it
If there is not a replacement you can remove the wires from the switch and wire them together. Make sure you unplug your bowflex before doing this. If it has only two wires it will be easy. If more than 2 wires take a photo and post it.
2/25/2019 4:34:47 PM • Bowflex Exercise... • Answered on Feb 25, 2019
Where is the reset button on tc10 treadclimber
On mine it is by where the power cord goes in to the machine... I thought ir was the powr on off button.. bu it is marked rest and does not turn the power off
1/20/2019 10:31:16 PM • Bowflex Exercise... • Answered on Jan 20, 2019
Bowflex SelectTech 552 Dumbbell Pair  Redesigned for 2009! Logo
5 questions posted
Top Bowflex Exercise & Fitness Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a Bowflex Exercise and Fitnes Expert? Answer questions, earn points and help others
View Most Popular
  • Bowflex Exercise & Fitness
Most Popular Question
need weight from
  • Exercise & Fitness
