20 Most Recent
Onkyo TX-SR700 Receiver Questions & Answers
Volume is stuck on max.
Do you have the manual and have you thumbed through it?
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Onkyo-TX-SR700-Receivers-manual/id/365ag223/t/2/
It always puzzles me when someone fixates on the remote when a unit has front-panel controls. You say "The pot does not seem to be the issue." Does that mean it is ineffective or is it faultless in your estimation?
The HUGE volume knob (#16 on page 8) controls volume (in the main zone), too.
If your complaint involves speakers on Zone 2, the up/down arrows at #22 on page 8 apply.
Can I connect my Denon
It looks like there are digital inputs on the left side of the ax10 (looking from the back )that you could plug right into with RCA cable. Use zone three on the AVR and remember these are pre-amped connections so little gain will be needed. Also only audio no video can be sent.
good luck
Joe
Onkyo Zone 2 problem
The zone 2 will only play analog sources - so you must hook up the output from the tv/cable/dss on it's analog (RCA Jacks) into an input on the Onkyo. You might also have to enable this output from you tv/cable/dss.
0-83 error on onkyo tx nr 555
The 0-83 error indicates a problem with the firmware update.
Try resetting the receiver's BIOS by following these steps2:
Unplug all cables
Un-Power the receiver
Power the receiver
Before the receiver gets into the "Enter for updating" message, press Tone + CBL/SAT + ON/STANDBY. This will show you either the volume numbers or get you into settings of the receiver's speaker configuration.
Press CBL/SAT + ON/STANDBY. This will clear the BIOS and show a "Clear" message on the display. Wait until you hear a couple of clicking sounds for the receiver to turn on and off the power.
TX-NR555 Owner's Manual - Onkyo Product Support (onkyousa.com)
Onkyo nr 555 stuck on recovery:NET
Hello
Did you update the AVR over the internet?
If so the device wont work anymore.
You need to service the device in a nearest Onkyo service department.
Regards
Onkyo powered subwoofer SKW-791
Oknkyo SKW-791 has build in amplifier. So it can be connected through Line Out Connector of sansui amplifier. If speakers out is connected with subwoofer, the circuit board in subwoofer will be blown.
