20 Most Recent
SYMA Toys industrial 9077 Double Horse Eagle Helicopter A Blade Main Motor Unit Questions & Answers
Double Horse 9053 Volitation Gyro cuts out
Most likely a fault with the PCB circuit board and needs replacing. Also check the motors and rotors are running freely as this could also cause the PCB to trip off.
Kind regards, julian.
rccontrolfreak.co.uk
1/31/2014 1:41:10 PM •
SYMA Toys...
Answered
on Jan 31, 2014
SO33G charger over heat ,
It is no use to buy a new charger if the problem is a short. Indications are that it is. When the batteries are in need of replacement and wont charge up, overheating of the charger will also occur.
1/3/2018 11:10:24 AM •
SYMA Toys...
Answered
on Jan 03, 2018
Syma so33g lower blades do not rotate
wrong!!! if the bottom set of blades aren't turning its because the drive gear for that shaft is loose and is spinning on the shaft instead of spinning the shaft itself. try tightening the screws but make sure the screws are lined up with the holes in the shaft so they seat otherwise your going to strip the plastic gears threads. if that doesnt work then you will have to replace the gear and shaft. its a cheap part and readily available. only problem is youll have to take apart almost the entire heli to get the old one out n the new one in. the gear comes pre-mounted on the shaft. Buy 2 or 3 of them right away as you will have to replace it just about every time your heli tips over while the blades are turning. the screws only go into the shaft about a 16th of an inch and is easily stripped out
12/26/2012 8:25:07 PM •
SYMA Toys...
Answered
on Dec 26, 2012
