20 Most Recent
Fisher Price Laugh and Learn Baby Grand Piano Questions & Answers
I bought my daughter the
Hello, Bugsy243 -First, did you replace the batteries in the Laugh & Learn Baby Grand Piano?If you do not know how to do that, this is the link to the instructions (PDF document):
https://service.mattel.com/instruction_sheets/J9163pr-0920.pdfYou will need Adobe Reader software (free) for the PDF document. If you choose to save it after downloading, I suggest you save it to your Documents folder and give the file a name you can find later . . . something like: Fisher Price Baby Grand Piano. You can also print the instructions for easy reference.The instructions for the toy state in the CARE section (page 2):* This toy has no consumer serviceable parts. Do not take this toy apart.Note: I do not find any other troubleshooting information (besides changing batteries) in the instructions.Page 6 of the instructions provides the phone number for Fisher Price Consumer Relations:800-432-54379 AM - 7 PM (Eastern Time), Monday - Friday11 AM - 7 PM (Eastern Time), SaturdayNote: This is the telephone number for the USA. The bottom of Page 6 of the instructions gives numbers for other countries.After changing the batteries, if the toy piano still does not operate properly, I suggest calling Fisher Price Consumer Relations to find out if there are tips for correcting the blue key and sun hands problems.Note: If you find the toy piano still does not work properly and choose to purchase a replacement, please send the non-working toy to electronics recycling.Best wishes.
Can you take the legs off
if u remove the legs it will make the system board free , is not recommended but you can cut the legs and sand but you can never use it again sorry bay it help.
I would like to disassemble
Should just use a philips head screwdriver. All screws are probably on the bottom. All electronics are probably screw down to the top white part. Hope this helps.
Not working - no power,
Check the battery connections for corrosion. An emory board, finger nail file will help remove
any debris and may help it come to life. After cleaning the connections put the batteries
back in and with the toy on press the buttons and twist the batteries. Sometimes moving the batteries
will show you which one has the corrosion and you can clean it from there.
Good luck.
How do I fix the Fisher price merry go round? And put it back together? The mechanism was made in Switzerland
How to assemble:
Steps:
Mechanism casing upside down:
- insert man
- insert on/off switch
- insert small cover
- insert small gear
- insert H shaped part at the gear opening
- align base and screws in w 2 screws
Right side up:
- attach big gear and axel to small gear inside casing
- place scoring under axel and onto the base
- align merri go round against mechanism and 2 screws
Upside down:
- screws 3 more screws of merry go round piece
Switch from French back to English
Check inside where the batteries are stored. There may be a switch that changes the language and it might have gotten jostled and switched on its own. If still no luck, remove and replace batteries to see if it resets. If that doesn't work contact Fisher Price customer service for more assistance. Bonne Chance! (That's Good Luck in French) If you haven't fixed your toy yet, you might already know that. =) Au Revoir
How to open FP music box record player, #995 or #995N
Fisher Price Music box: to open, remove the four screws from the bottom, open the two parts as wide as possible without using too much force. Using a small flat blade screw driver, insert between the red cover and white top where the wind up knob is located. Pry the red bottom out far enough to allow the ring surrounding the knob to slide under the red bottom. The box is now open.
After repair, and re-assembling, make sure the wider part of the wind up stop wheel faces the front of the player, otherwise the wind up knob catches and slows the mechanism.
