20 Most Recent
Sova Digital DS204-DS26 Television Questions & Answers
Sound no pic
Yes,ur Main Tuner signal board have problems,just not dead yet.Replaced the Tuner signal board,should solved ur problems.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish Tuner signal board for the replacement.
When turniing on, screen stays black and the led
U can use it that way,if u want too.But the problems it the power supply board.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement will solved this problems.
Green power light comes on no picture but has
You either have a bad inverter board (most likely) or a bad control board. The fact that your unit seems to work OK would lean me towards the inverter board. Remove all the screws from the back. There are more than 2 doz. Be careful, don't force anything. Once the back is off identify the inverter board. You can get a new one from
www.partstore.com Remove all plugs, mark if necessary. Remove old board, install new board, install connectors and reassemble unit. Your set should now be working. Let me know how this works out and whether you need any additional help.
hardrocko
Broken remote
This is a no-name type TV set. You can try eBay, or visit a lot of flea-markets to try to find a remote.
Maybe you can take a chance and try a universal remote. Universal remotes do not give all the functions.
Next time you buy a TV set, make sure you buy a known quality name brand, and that there is a source for parts and service.
Jerry G.
Wall mounting
The owners manual should tell you if wall mounting is possible.
Monitor problem
Took my Sova to a repair shop and was told (after a $75 fee) that they could not get the parts, and if they could it would cost more than the TV was worth. What I need is a main board if you here of were it is available, Please let me know!
