20 Most Recent Fisher Price Power Wheels Cadillac Escalade Questions & Answers
have the fault codes read to determine the problem sensors
Fisher Price... | Answered on Jun 04, 2017
Test the charger with a ohm meter, or you could take the vehicle to a Power Wheels service station, they can test the battery for you to see if it is good.
You can find your closest service center here: http://service.mattel.com/us/powerwheels_info.asp
If you end up needing a replacement battery or charger they can be found here: http://www.mendingshed.com/powwheelbat.html
Let us know if you need any more help.
Thank you,
Colleen
Customer Service
MendingShed.com
800-339-9297
Fisher Price... | Answered on Apr 12, 2013
I have NO CLUE but it bet its a simple piece of Chinese plastic. Look down at the shifter, USE screw driver to remove shifter, remove Chinese plastic blocking the shifter from being pushed into HIGH by young child. Reattach shifter, push shifter forward to HIGH.
Fisher Price... | Answered on Aug 27, 2012
usually i just use a needle nose pliers and bend it in half then you can pull it off, but doing it this way will wreck the push nut, the other option is to take a flat head screwdriver and work your way around and slowly pry it up
Fisher Price... | Answered on May 02, 2012
hi, you need a forward/reverse switch. here is a link to one...
http://www.hobbymasters.com/search.aspx?find=00801-0923
good luck!
Fisher Price... | Answered on Feb 02, 2011
check it out in user manual
Fisher Price... | Answered on Dec 31, 2010
The shifter has two switches that it operates. Reversing the connecting plug on one of the switches will most likely solve your problem. It worked for me. The casing of the shifter should have a label "white" by one of the switches, leave that one alone, rather flip the plug going to the next one.
Fisher Price... | Answered on Aug 10, 2010
I have find out the Fisher Price Contact number. Please visit this website http://service.mattel.com/us/ContactUs.aspx
Hope it can help you. Thank you!
Fisher Price... | Answered on Jul 05, 2010
Fisher Price Music box: to open, remove the four screws from the bottom, open the two parts as wide as possible without using too much force. Using a small flat blade screw driver, insert between the red cover and white top where the wind up knob is located. Pry the red bottom out far enough to allow the ring surrounding the knob to slide under the red bottom. The box is now open.
After repair, and re-assembling, make sure the wider part of the wind up stop wheel faces the front of the player, otherwise the wind up knob catches and slows the mechanism.
Fisher Price... | Answered on Nov 22, 2019
Contact them direct for repair. The Contact link is at the bottom of the page.
https://www.fisher-price.com/en_ca/index.html
Fisher Price... | Answered on Nov 05, 2019
As we can not fully see the damage my best bet would be to take it to a local "Mens Shed" where I'm sure they can fix it for you.
Fisher Price... | Answered on Jun 06, 2019
Check power supply and switch operation.
Fisher Price... | Answered on May 28, 2019
Contact Fisher Price directly to request the manual.
Fisher Price... | Answered on Apr 18, 2019
my grandsons broke their mother's (and aunts') FP music box.
There was almost no sound
The teeth are simply a wind-up music box set, connected to a rod that transmits the vibrations to the diaphragm under the pseudo-tone-arm. I was able to fix by placing a cotter-pin on the rod in the arm at or near the junction and then trim with wire cutters to the correct size.
I checked the diaphragm first by tapping it through the arm/table connection.
Fisher Price... | Answered on Apr 06, 2019
Try to put it new batteries. If not notify the person you bought it from or the store and ask for help or refund.
Fisher Price... | Answered on Jan 29, 2019
Fisher Price Power Wheels Cadillac Escalade Logo
Popular Tags
19 questions posted
Top Fisher Price Toys Experts
Marvin
Marvin
NOEL
NOEL
yobo007
yobo007
Are you a Fisher Price Toy Expert? Answer questions, earn points and help others
View Most Popular
Fisher Price Toys
  • Fisher Price Toys
Most Popular Question
u remove push nut
  • Toys
