20 Most Recent
Peg Perego IGOR0040 John Deere Turf Tractor with Trailer Questions & Answers
I believe the wires run directly from the battery to the switch that makes it run without a fuse. Check to make sure the switch is fully plugged in under the pedal. You will also want to check the charge on the battery, which a store like Batteries Plus should be able to do. Might be a bad battery as well.
I need to remove the
you can do this by popping of the black hub center of one wheel and then use a needle nose pliers and bend the metal push nut in half this should allow you to pull it off and then remove the washer and then the wheel, this should allow you to pull out the axle and wheel from the other side, then you should be able to pull the motor and gear box out
How do I remove electric
i would remove the wheels and the axle from the rear, you can do this by popping of the black hub center of one wheel and then use a needle nose pliers and bend the metal push nut in half this should allow you to pull it off and then remove the washer and then the wheel, this should allow you to pull out the axle and wheel from the other side, then you should be able to pull out the motors and gearboxes, then use a small screwdriver to get the wires disconnected from the motors and then there should be two screws that hold the motor to the gear box, then jus do the preceding in reverse order to put it back together
John deere turf tractor has
check the battery with a multimeter and see if its showing 12 volts or more, if its not showing any volts the connectors on the battery under the plastic housing have probably come disconnected, you'll then have to pry off one side of the battery and reconnect them, if it is showing volts but not 12 or more then put it on the charger for about 8 hours, then check the battery again if it still hasn't went up check the voltage of the charger with the multimeter and make sure that the charger is putting out 13.8 volts or more, iif it isn't then you need a new charger, if it is then you need a new battery
How do you get the
unscrew the little screws on each side of the hood and then remove the little green plastic piece behind it then you might have to pull out a little bit on each side then tilt forward
Peg Perego Thomas The Train - Ride On wont go but horn &whistle works
If the Peg Perego Thomas The Train ride-on is not moving but the horn and whistle are still working, it's likely an issue with the motor or the gearbox. Here are a few troubleshooting steps you can try:
- Check the battery: Make sure the battery is fully charged and properly connected. If the battery is old, it may need to be replaced.
- Check the wiring: Inspect the wiring for any damage or loose connections. Ensure that the wiring is properly connected to the motor and gearbox.
- Check the motor: The motor may be burnt out or malfunctioning. Use a multimeter to test the motor and see if it's receiving power.
- Check the gearbox: The gearbox may be jammed or worn out. Inspect the gearbox for any damage or obstructions. Try lubricating the gears with some WD-40 to see if that helps.
If none of these steps resolve the issue, it may be best to contact Peg Perego customer service or take the ride-on to a certified repair shop.
