20 Most Recent
Citizen Eco-Drive BL006056H Wrist Watch Questions & Answers
Setting time for citizen eco-drive E764-S066701 HST perpetual movement
No need to take the back cover off or anything like that. You don't need jeweler either. You just need to pull the crown to first "click" and the turn the crown to the right to correspond to the month that you are setting the time in. Between 1 and 2 o'clock represents January. Between 2 and 3 is February and so on. Once you get to the beginning mark of the month you are in, count how many years have passed since the last leap year. If it's 2 then put the second hand to two minutes after even (beginning). If it's three, move it to three minutes after. If it's leap year, you just put on exact (beginning) mark of the month you are in.
That would be it. Like I have said, no need to visit jeweler or do any disassembling. Also, you might this find interesting. The steps above are for E764 calibre. This site gives you manuals for pretty much all of them.
11/1/2014 6:35:22 AM •
Citizen...
Answered
on Nov 01, 2014
Change battery how do i change battery?
It's a rechargeable battery. It is under a small circuit board after the back is off. Don't attempt to do this yourself unless your are experienced. Battery ( capacitor) is about $30 online
8/13/2014 7:49:34 PM •
Citizen...
Answered
on Aug 13, 2014
My watch won't stay charged
Your watch needs a new capacitor ( rechargeable battery of sorts) take it to a jeweller unless you have tools and know how.
8/13/2014 7:45:32 PM •
Citizen...
Answered
on Aug 13, 2014
Wrist watch shortening
Look at the inside of the band and there will arrows pointing what direction the to tap the pins out to remove links. Put the watch on a small roll of tape or something similar that keeps the band off the surface you are working on. Gently tap the pin out with a tool that will fit in the pin hole. Remove the pin and determine the number of links to remove. Remove the links and reverse the order in which you took it apart .
8/13/2014 7:42:54 PM •
Citizen...
Answered
on Aug 13, 2014
Citizen Eco Drive
A "non" fully charged watch will sometimes "jump" seconds rather than indicate one second intervals. Charging these small solar panel watches takes forever, in BRIGHT sun. Have you tried leaving it outside, in the sunlight, for at least 12 hours?
5/1/2013 5:42:30 PM •
Citizen...
Answered
on May 01, 2013
