20 Most Recent
Rowenta DW9080 Iron with Auto Shutoff Questions & Answers
POWER CUTS ON & OFF. IF I JIGGLE CORD WHERE IT
The wire is already damage specially the other end that goes trough the iron try to replace the wire or you can trace the damage wire using a continuity tester then cut the damage wire then try to connect the other half it is usually screwed in the heating element. The leaking part of the iron below the face plate you can use a silicon adhesive to cover the leak. Good day and best regards.
How do you fix a seal on a Rowenta Iron?
To try and seal the water leak will possibly render the appliance dangerous.
I would speak to Rowenta and ask the question. They may well extend the warranty if you suggest it wasn't used for say a few weeks after purchase etc.
