20 Most Recent Cuisinart FP14DC 14 Cups Food Processor Questions & Answers
Metallic sound when turned on & blade is not
Hello
There's a good chance the drive belt or the drive gear is the cause. You can fix either problem with a pair of screwdrivers and, if need be, a replacement part or two.
If you are Dealing with a worn or broken belt;
Unscrew the machine's base, using a screwdriver. You may need to pry off the rubber feet to access some of the screws.
Inspect the drive belt,If it is slack, loosen the screws holding the motor assembly, and follow step 4 to increase the belt's tension. If the belt is broken, get a replacement from an appliance store or the manufacturer.
Install the new belt. Loosen the screws holding the motor assembly, and shift the drive gear toward the reduction gear so you can slip the belt over each gear.
Shift the drive gear away from the reduction gear to increase the belt's tension, then tighten the motor-assembly screws.
If you are dealing with a worn drive gear;
Inspect the drive gear. If the teeth are worn, you need to replace it. Remove the drive belt as described above to access the gear.
Remove the gear, using an Allen (hex) wrench to loosen the setscrew in the side. Then buy a replacement from an appliance store or the manufacturer.
Slide the new gear onto the drive shaft, and align it so the center is parallel to the center of the reduction gear. Tighten the setscrew with the Allen (hex) wrench.
Replace the belt, and increase the tension as directed in step 4, above.
Reinstall the base and any rubber feet you removed.
NOTE
If the drive gear is hard to remove, tap it gently with a hammer to loosen it, then pry it off with a flathead screwdriver.
To avoid electric shock and prevent your fingers from getting jammed in moving parts, always unplug your food processor before disassembling it.
10/8/2011 7:35:04 PM • Cuisinart FP14DC... • Answered on Oct 08, 2011
I don't have an instruction manual (wasn't
A manual for the FP-14C series which the Cuisinart site indicates is applicable to your specific model is available online:
http://www.cuisinart.ca/pdf/ibs/en/FP-14DCC_en.pdf
See page 8 for assembly instructions. Beginning on page 20 is an included recipe section.
For future reference available Parts & Accessories are listed here:
http://www.cuisinart.ca/cuisinart_parts_accessories.php?product_id=328&item_id=281&cat_id=7
8/13/2011 6:36:55 AM • Cuisinart FP14DC... • Answered on Aug 13, 2011
My Cuisinart Class Pro 'Off' button doesn't turn off, it just keeps running. To turn it off I have to unlock the lid.
Don't switch off using the lid interlock or that will be next to go. It is to stop you from running it without the lid. Turn it off at the wall socket. Cuisinart Spares https://www.google.com/search?q=Cuisinart+Class+Pro+parts ..
1/7/2024 2:46:52 AM • Cuisinart Food... • Answered on Jan 07, 2024
2answers
The bowl on my cuisinart food processor is locked in place. How can I unlock it to remove the bowl?
You don't say what model, but all Cuisinarts have a safety interlock built in to the bowl assembly. The cover must be removed from the bowl to release this interlock before you can remove the bowl from the motor base.
4/9/2023 4:51:48 PM • Cuisinart Food... • Answered on Apr 09, 2023
Safety pin on food processor won't retract
It sounds like the safety interlock system on your Cuisinart 14 cup food processor is engaged, preventing the bowl from fitting securely onto the base. Here are some steps you can try to resolve the issue:
  1. Unplug the unit from the electrical outlet.
  2. Use a small, pointed object such as a toothpick to gently push the white safety pin up and out of its locked position. This may take some effort.
  3. Check the base of the food processor for any obstructions or debris that may be preventing the bowl from fitting correctly. Clean any debris you find.
  4. Reinsert the bowl onto the base, ensuring that it is properly aligned and twisted into place.
  5. Press the bowl down firmly onto the base until you hear and feel it click into place.
  6. Plug the unit back in and test it to see if the safety interlock system has been disengaged and the food processor is working normally.
If these steps do not resolve the issue, it may be necessary to take the unit to a professional repair technician or contact Cuisinart customer service for further assistance.
2/26/2023 9:45:40 AM • Cuisinart Food... • Answered on Feb 26, 2023
Cuisinart 13 cup processor blade will not spin with food in bowl
That is a sort of clutch to protect the motor. Try Cuisinart direct and be sure to include the model number, '13 cup' is just a size to all the 13 cup models they have made over the years. https://www.google.com/search?q=cuisinart+elemental+13-cup+food+processor+replacement+parts You may be able to repair those hooks with J-B Weld Liquid Metal or epoxy putty. If you can clean it well, it is extremely strong. https://www.google.com/search?q=J-B+Weld ..
12/29/2022 6:27:13 PM • Cuisinart Food... • Answered on Dec 29, 2022
My Cuisinart DLC-8S Pro Custom Food Processor needs a detachable stem.
eReplacement Parts states that is the right part. https://www.ereplacementparts.com/cuisinart-dlc8s-pro-custom-food-processor-parts-c-147322_147329_147425.html How about direct from Cuisinart Kathleen? Although strangely, they quote part DLC-839ATX-1 as the correct one. Could your processor NOT be a DLC-8S I wonder? https://www.cuisinart.com/shopping/parts-and-accessories/details/dlc-839atx-1 ..
2/25/2022 6:06:51 PM • Cuisinart Food... • Answered on Feb 25, 2022
Cuisinart lid put on incorrectly and will not come off FP-8 series
try WD40, then heat it with a hair dryer
12/2/2021 3:58:51 AM • Cuisinart Food... • Answered on Dec 02, 2021
Cuisinart Food Processor (14 cup
For cuisinart food processors that won't shut off: with bowl off - not attached - hold OFF button down while plugging in. With a screwdriver or other implement, press the button that gets depressed on motor base when bowl is attached and snapped into place ( small flat rectangular piece that clicks the bowl into place. While still pressing OFF button, press this a few times times, unplug then release the OFF button. I tried several suggested combinations of button pushing and unplugging, and this seems to have fixed it!
4/14/2021 1:16:28 PM • Cuisinart Food... • Answered on Apr 14, 2021
The stem in the DLC-8E Cuisinart food processor does it just pull straight up off the motor shaft?
Yes it does. It is a snug fit on the blade shaft, if you mean the tall shaft that powers the shredder discs? The short one that holds the cutting blade is not removable.The tall stem is shown hereCuisinart DLC-8 Detachable StemItem # 943070https://www.kitchenworksinc.com/cuisinart-food-processor-parts/cuisinart-dlc-8-parts/..
1/31/2021 8:36:38 PM • Cuisinart Food... • Answered on Jan 31, 2021
My cuisinart food processor won't turn off without unplugging it FP 14 series any suggestions
The control board (AKA PCB) will need to be replaced.
12/8/2020 10:27:03 PM • Cuisinart Food... • Answered on Dec 08, 2020
I have a vintage Cuisinart DLC 8M processor. I need to replace the work bowl and have found a DLC 8F online. Would the work bowl from the 8F fit my 8M?
The DLC-8F bowl will not work for the DLC-8M, as I understand the parts list for the 11 cup food processors. However, this site, https://www.kitchenworksinc.com/cuisinart-dlc-8-4-piece-tritan-bowl-kit/ , has a work bowl for the DLC-8 food processor. The bowl fits all models of DLC-8 except the DLC-8E and DLC-8F. The link for the work bowl alone is https://www.kitchenworksinc.com/cuisinart-dlc-8-tritan-workbowl/ . I hope this helps. Cindy Wells
6/1/2020 6:04:12 PM • Cuisinart Food... • Answered on Jun 01, 2020
3answers
I need 2 replacement rubber feet for Cuisinart FP-12DC ELITE 12 cup food processor. Cuisinart says they do not sell them seperatly. Can you help?
go to a rubber products shop and get the rubbers or rubbers that will do the job
2/4/2019 6:00:38 AM • Cuisinart Food... • Answered on Feb 04, 2019
My Cuisinart food processor will not start. I have only used it a couple of times.
Hello, Sally -Make sure you have the work bowl properly placed on the base and the lid properly attached to the work bowl. I often have trouble getting the work bowl inserted in the base of our food processor and also have trouble getting the lid fitted into the bowl properly.Since I have no idea which model of Cuisinart food processor you have, I am unable to advise you further.You can contact Cuisinart Product Assistance:US toll free number:800-726-0190Monday to Friday, 8:00 AM - 10:00 PM (Eastern Time)Saturday and Sunday, 9:00 AM - 5:30 PM (Eastern Time)Best wishes.
1/3/2019 8:47:04 PM • Cuisinart Food... • Answered on Jan 03, 2019
tip
Don't throw out your Cuisinart-Keurig SS-700 if the switch is broke.
Would you pay $1.84 to fix it? Cuisinart does NOT carry the #1 part most likely to fail, the on-off rocker switch. Most of the parts they do carry you'd only need if you were careless and broke the item, but the switch gets daily use and these snap-in switches are not made to last to begin with. The switch is not listed on their web site and if you call they will tell you it's time for you to buy a new machine. If you are a handyman to the extent of having a solder iron and a Phillips screwdriver then the switch can be bought from a commercial electric/electronics supply house. The shipping costs seven times more than the switch, and much more if you want air freight. The switch itself is $1.84. It's a medium task and will take about 30 minutes tops. The most time taken was 7 days waiting for the normal shipment to arrive. It's PN 15N8920 from Newark Element14 @ "https://www.newark.com/". They are a wholesaler and I didn't volunteer that I wasn't a contractor or business. In the online order form when it asked for company I filled in "Retired" and I answered all the other application form questions they had so I could return there again I needed something they carried. Their form didn't ask if I was a re-seller and my answer would have been "no" but if it had gone down that rabbit hole I may not have been able to order. In my order I bought two of the switches; by the time my SS-700 fails and needs another switch I'll probably be glad I bought the backup. For Cuisinart not to carry that switch is planned obsolescence IMHO. Yes, a homeowner who is not handy with some basic tools might be unable, but even a small town repair business might not go through the trouble I did because they'd have to pay and pass along to you the $20 (90% for shipping)for the part, and by the time they add on a reasonable charge for labor your bill would probably be $70-$90. Facing that amount you might think buying a new one is best for you, you'd get all new, the latest, including a warranty. Imagine if an Ace Hardware or Home Depot carried that switch (I looked), I'd have had it working the same day. Keurig could buy a higher quality switch to manufacture with, but there's more revenue for them going the way they are now, and this planned obsolescence every product maker uses puts more permanent waste in our landfills.,
Cuisinart mini-processor, motor runs but blades get stuck and motor just spins? I tried replacing blade, no help
The set screw on the blade assembly is loose. If the motor does not spin then that is a different story.
12/10/2018 3:29:57 PM • Cuisinart Food... • Answered on Dec 10, 2018
Cuisinart FP14DC 14 Cups Food Processor Logo
3 questions posted
Top Cuisinart Food Processors Experts
vince
Are you a Cuisinart Food Processor Expert? Answer questions, earn points and help others
View Most Popular
  • Cuisinart Food Processors
Most Popular Question
don 39 t instruction manual wasn 39 t
  • Food Processors
