20 Most Recent Samsung RFG297AA (285 cu ft) Bottom Freezer Commercial French Door Refrigerator Questions & Answers
SAMSUNG #RFG297AA door magnet seals are failing
I believe there is a 5 year warranty on that. Call Samsung. Don't use their live chat. http://www.samsung.com/us/support/contacthttp://www.samsung.com/us/appliances/refrigerators
11/19/2018 6:32:33 AM • Samsung RFG297AA... • Answered on Nov 19, 2018
Frig wont cool fan not running freezer working
fan is not working thus u have very little cold air circulating into the fridge. check the fan with a multi meter for continuity? it may be out? When u say freezer working? is there an ice build up ? if so u may have a bad defrost terminator or defrost timer, which in turn blocks the fan from working due to ice build up?
3/22/2015 8:22:18 PM • Samsung RFG297AA... • Answered on Mar 22, 2015
Will not feeze
Turn ref. off for 24 hr's
5/22/2014 2:03:01 AM • Samsung RFG297AA... • Answered on May 22, 2014
Water leaks when icemaker full
Replace the icemaker
7/10/2013 11:18:30 PM • Samsung RFG297AA... • Answered on Jul 10, 2013
Samsung refrigerator dispenser makes noise after filling water glass
You may need to have the water filter replaced. This sounds like it is starving for water as it refills.
2/4/2013 1:39:27 AM • Samsung RFG297AA... • Answered on Feb 04, 2013
I WOULD LIKE TO GET SERVICE, & NEED TO ORDER A PART,
What is the model number of your unit?
11/1/2012 9:59:55 PM • Samsung RFG297AA... • Answered on Nov 01, 2012
Samsung rfg297aa display for both the freezer and
You frig is in Demo Mode. Hold your energy save anf freezer temp button for 3 seconds or until chimes and you should be good to go!!
2/5/2012 2:29:13 AM • Samsung RFG297AA... • Answered on Feb 05, 2012
My samsung rfg297aa dispenses crushed ice whether
This answer probably comes too late for you (you posted the question 9 months ago), but I want to record it here for posterity, since I had the same problem, and searching on Google for it brought up your question.Anyway, I managed to fix this very problem by removing an ice cube that was wedged in the ice dispensing mechanism. The way this unit works is that it pushes the ice cubes through the mechanism, which always rotates the "crushing blades". When you select "cubed" ice, a lever opens up the exit chute wider, which causes the blades to simply push out the ice cubes as they pass through. When you select "crushed" ice, the lever closes the "exit" for the ice cubes to be narrower, so that the ice cubes can't be pushed through by the blades, and instead get crushed by them. I had an ice cube wedged in there that had the same effect of closing the exit to be narrower. Removing it fixed the problem.You might want to collect all the ice cubes that have accumulated in the ice bucket in a container, empty the ice bucket, clean out the mechanism from any obstructions, and then put the ice cubes back into the ice bucket.
11/7/2011 4:43:08 AM • Samsung RFG297AA... • Answered on Nov 07, 2011
My Samsung refriderator (model RFG297AA) started
Hi!
A relay starts the compressor with a higher voltage and then quickly kicks out
It does a lot of clicking (trying to start over and over again)
If thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
I use part no ERP410 POWER START RELAY, CAPACITOR AND OVERLOAD all in one. (110 v)
If you still have trouble Go Here:
http://www.applianceaid.com/procedures.html
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
9/11/2011 8:27:39 PM • Samsung RFG297AA... • Answered on Sep 11, 2011
Left side of freezer door
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned WARMER WHICH MAKES THE REF COLDER AND VICE-VERSA. SEE?
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
But is probably a common defrost problem The ice build up
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If
you need more help go here:
MORE
TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
8/31/2011 1:25:27 AM • Samsung RFG297AA... • Answered on Aug 31, 2011
LOST ALL POWER FOR FRIDGE/FREEZER
samsung refrigerator show 88 88 on ice maker please help
7/16/2011 2:33:46 PM • Samsung RFG297AA... • Answered on Jul 16, 2011
Stoped colling
just confirm the model and brand.
Also could you please give some more details of the problem, like what you have notice, temperuatures in freezer fridge, compressor, condenser fan, evaporator fan are they working or not and the history of the problem and also any actions of yours and the results
10/21/2010 6:20:23 PM • Samsung RFG297AA... • Answered on Oct 21, 2010
My Samsung Space Icemaker makes ice very slowly.
Yes, this is a "known" issue with the Samsung's refrigerators. You need to order a new icemaker. The icemaker will come with a brand new control board with new firmware. Replace both of them and this will fix problem. The control board should be located at the back of refrigerator under back panel
9/26/2010 3:50:37 AM • Samsung RFG297AA... • Answered on Sep 26, 2010
Icemaker is not working.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
9/12/2010 12:22:32 AM • Samsung RFG297AA... • Answered on Sep 12, 2010
Samsung RFG297AA (285 cu ft) Bottom Freezer Commercial French Door Refrigerator Logo
Popular Tags
43 questions posted
Top Samsung Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Samsung Refrigerators
Most Popular Question
samsung refrigerator dispenser makes
  • Refrigerators
