20 Most Recent Samsung RS2530BSH (25 cu ft) Side by Side Refrigerator Questions & Answers
My Samsung Refrigerator Model:
Replacing the condenser fan that's not working will most likely solve the problem
9/8/2017 1:49:29 PM • Samsung... • Answered on Sep 08, 2017
Refrigerator or freezer won't get cold
have you checked the connection at the compressor relay or checkec to see if it has burned out it is next to the compressor
4/22/2017 5:18:39 PM • Samsung... • Answered on Apr 22, 2017
Refrigerator not cooling
It is broken
6/9/2015 1:06:48 PM • Samsung... • Answered on Jun 09, 2015
Compressor hot, draws 9amp tried hard start kit with no joy. used external 120vac windings not grounded, windings ~3 ohms ~ 8 ohms,
Dear Robert,
  • I am assuming you clean the coil.
  • Compressor may test out good electrically but has a mechanical failure inside.
  • Check the Run Cap.
  • Here is a link to the Service Manual.
http://www.manualslib.com/download/446846/Samsung-Rb215bssb.html
  • Click on it or paste to your browser.
Let me know the turn out. Good Luck, JP
6/8/2015 5:18:01 PM • Samsung... • Answered on Jun 08, 2015
Location of the drip pan for samsung RS2530bsh
usually under fridge front or back
4/3/2015 2:02:02 AM • Samsung... • Answered on Apr 03, 2015
My power went out and since it was restored my fridge won't come.
IIRC your refrigerator has an electronic control in the front face of the freezer door. Both sides have 3 buttons in a vertical column. Is there any sign of life on this control panel (IE do you see the stack of horizontal green bars lit up and does pushing the "freeze" or "fridge" button change them)? If not, then the most likely scenario is that you had a big power surge when the AC voltage came back and it blew out your control panel. If you can install an adequatley rated surge protector in the power line for your refrigerator you can prevent this from happening again.
5/29/2014 5:46:51 PM • Samsung... • Answered on May 29, 2014
0answers
Samsung RS2530 fuse
Be the first to answer 4/11/2014 11:25:06 PM • Samsung... • Posted on Apr 11, 2014Be the first to answer
Not making ice
Does the water line to the freezer have a filter on it? If so, try replacing ththe filter
9/15/2012 7:25:59 PM • Samsung... • Answered on Sep 15, 2012
Ice maker has ice motor doen't dump the ice
Your ice-maker may need to be "hard-reset". To do this, perform a manual-defrost by emptying out the freezer (and fridge) and shutting all power off to your unit for several hours (at least half a day unless you can be sure the temp in the freezer has fully reached ambient. Next, with freezer empty, restore power, make sure the "ice" setting is set to off, then set the forced power-freeze mode (you can refill the fridge, but leave the freezer empty for now. When the power-freeze completes (at least 2.5 hours) you can refill the freezer, set the "ice" mode to block/crushed (IE something other than off) and then hit the "black reset button" to restart the ice-maker. IF it still will not dump the cubes then the ice sensor/control board may have failed.
7/7/2012 8:01:32 PM • Samsung... • Answered on Jul 07, 2012
My samsung rs2530bsh is heating
this is because the condenser fan is not doing its job open the lower panel in the back of the unit and make sure that the (condenser)fan is working if it does then the coild and very dusty , get a long brush and clean the condenser coils you will see a diff. right away
9/5/2011 2:49:39 PM • Samsung... • Answered on Sep 05, 2011
Freezer stop freezing, need to
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned WARMER WHICH MAKES THE REF COLDER AND VICE-VERSA. SEE?
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
But is probably a common defrost problem The ice build up
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If
you need more help go here:
http://www.applianceaid.com/procedures.html
MORE
TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
8/31/2011 12:30:27 AM • Samsung... • Answered on Aug 31, 2011
2answers
ICE MAKER NO LONGER WORKS, REFRIG DOES NOT GET
NOTE: This
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
First I would check the fan in the freezer. Listen to see if it is running
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
8/10/2011 12:36:30 AM • Samsung... • Answered on Aug 10, 2011
I replaced fan motor,how do i get it too reset,so
Could you give some more details so we can realise what is the problem and what you have done and what you are trying to do.
7/26/2011 11:33:01 PM • Samsung... • Answered on Jul 26, 2011
I BOUGHT A MOTOR DAMPER,
I'm Leo
If this was helpful please rate me
Leo Ponder
imufo2
Thank you for using fixya
Leo Ponder
Please VOTE FOR ME IF THIS WAS HELPFUL.
Please click for article
7/26/2011 10:36:43 PM • Samsung... • Answered on Jul 26, 2011
Samsung RS2530BSH (25 cu ft) Side by Side Refrigerator Logo
65 questions posted
Top Samsung Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Samsung Refrigerators
Most Popular Question
samsung rs2530bsh heating
  • Refrigerators
