20 Most Recent Samsung RS2530BWP (25 cu ft) Side by Side Refrigerator Questions & Answers
2answers
Flashing green light on control panel
Samsung refrigerator RS2530bwp Cause: Power outage Symptoms: - One LED light flashing on console (in the Power Freeze section) - Not running (not cooling, but inside lights work, ice maker not working, ice crusher doesn't work, water wont dispense) Solution: Press and hold for at least 10 seconds Ice type button + Filter Reset button Console should light up. This is not documented *anywhere* on the web (until now). Best of luck
1/17/2023 7:51:26 AM • Samsung... • Answered on Jan 17, 2023
What part Samsung RS2530BWP uses, Sensor or Bar
either the heating element used to defrost is bad or there is usualty a small inline thermal fuse replace it test the elements resistance is aok look on ebay for a new inline fuse and also element save the grief of testing
12/2/2021 7:32:51 PM • Samsung... • Answered on Dec 02, 2021
Samsung model rs2530BWP cubed ice icon is blinking what does that mean
mine was doing this, i replaced the main board and power supply, it was still doing. i checked all the sensors and still didnt fix the problem, i then looked at the ice maker, there is a sensor on the ice maker that has two white wires off it, i used a jumper wire and touched them together at the plug in the freezer and it started working like it should, now i have to order a new sensor from what i can tell. part number DA97-00258E to replace the ice maker.
4/10/2019 2:38:52 AM • Samsung... • Answered on Apr 10, 2019
When the fridgerator is running it sounds like a
Some refrigerators have a circulation fan that blows into the refrigerated section. If yours is designed like this, it will be a blower separate from the coil fan and likely harder to access. I suspect the bearings on that blower are dirty or damaged.
12/13/2017 10:41:04 PM • Samsung... • Answered on Dec 13, 2017
Freezer and fridge not cooling,
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
4/20/2015 10:54:00 PM • Samsung... • Answered on Apr 20, 2015
Samsung rs2530bwp refrigerator will not start
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Sounds like the cold control has stuck . Unplug the two wires from the cold control and plug them together. Turn one wire over and plug it into the other. away from the cold control.
The cold control is the knob in the ref that turns it on and off and has numbers on it. (Thermostat)
If it runs then that cold control (Thernostat) is the problem.
If that doesn't work DO THIS:
The relay on the compressor may need replaced
A relay starts the compressor with a higher voltage and then quickly kicks out
Thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
also try hooking the two wires together on the cold control to route around the cold control.
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
3/27/2015 12:51:04 AM • Samsung... • Answered on Mar 27, 2015
0answers
Ice bin stuck
Be the first to answer 5/21/2014 4:07:49 AM • Samsung... • Posted on May 21, 2014Be the first to answer
0answers
0answers
Condenser fan
Be the first to answer 11/5/2013 4:15:13 AM • Samsung... • Posted on Nov 05, 2013Be the first to answer
0answers
0answers
SAMSUNG MODEL RS2533SW/CUR ICEMAKER MAKING ICE BUT NOT DUMPING
This sometimes happens with my KitchenAid ice maker.Usually there is a piece of ice stuck on the side where the sensor is that causes the ice to drop. I usually carefully chip away at any ice that is stuck. Once the stuck ice is removed, the ice maker works fine.
9/18/2012 2:01:50 AM • Samsung... • Answered on Sep 18, 2012
Why do i have to press the reset botton to get the
Verify that the compressor fan is working. The fan is located behind the unit at the bottom. You need to remove tha back panel and observe that the fan is working while the compressor is running.
1/19/2012 10:23:34 PM • Samsung... • Answered on Jan 19, 2012
Ice Maker: water freezes in tray, but no ice is
Check the freezer temperature. It must be below 10F in order for the Icemaker to operate. If you find that the temperature is above that, your problem is not the icemaker, but something else in your cooling system.
1/19/2012 10:20:16 PM • Samsung... • Answered on Jan 19, 2012
Samsung RS2530B Mother board is burned out. I am trying to find the proper replacement
go on samsung website and see if you can order one if you need more help email me at [email protected] im hvac/r certifide
1/14/2012 8:32:27 PM • Samsung... • Answered on Jan 14, 2012
Samsung RS2530BWP (25 cu ft) Side by Side Refrigerator Logo
44 questions posted
Top Samsung Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Samsung Refrigerators
Most Popular Question
flashing green light control panel
  • Refrigerators
