20 Most Recent
Bosch B22CS80SNS (220 cu ft) Side by Side Refrigerator Questions & Answers
IWD off is on the display panel of theside by side
Do you see a button called alarm/lock?
Press and HOLD that button for five seconds.If that does not work,Press and hold super and freezer buttons at the same time for five seconds.This would change the IWD off message.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Control panel light does
Does ANYTHING work? Sure it's plugged in, breaker not tripped and GFI plug not tripped?
Plug something else into the outlet to confirm that it works.
Unplug from wall for 30 minutes to reset Bosch to defaults.
Still malfunctioning? Main control board is faulty.
Despenser light no longer works.
if you mean light for water and ice dispenser they upgraded to a new led ring mine went out to you can get part from bosch parts website
Ice on bottom of freezer floor. Turned off fridge so it could completely thaw. Should I do anything else?
We have the same fridge, we just had the same problem, and followed the instructions found on this website. Probably a clogged drain pipe/tube.
After following these instructions, my husband found a chunk of debris in the tube along with a piece of plastic wire tie that was the probable cause of our issue - here is a copy of what we did last night. (The end of the tube has a little rubbery opening that drips into a pan at the base of the rear of the freezer - the beginning of the tube is behind the grill on the back wall of the freezer, have to put the wire through the grill and into the hole - we put the wire up from the bottom and down from the top to be sure to get the clog)
Remove all the drawers in the freezer - and stack them up.
With the unit switched off and unplugged, undo the fixings on the rear pannel in the freezer (behind the drawers)
Remove it to see the evaporator
coils etc.
At the base there should be a channel - and a hole leading to the drain pipe. This needs unblocking wih a thin flexible cable. -net curtain support wire is ideal, and cheap. or use a short length of insulated cable.
Check it comes out at the rear of the unit onto the evaporator container - situated on top ofthe compressor.
Replace everything and switch on.
