20 Most Recent
Liebherr KGT 3046 Premium Questions & Answers
Stop water collecting at the bottom of a 3046
What about the drain tube? Also, check to see if there is a rubber flap or "duckbill" valve on the drain tube. Sometimes the rubber on them gets soft and will stick, not allowing the water to drip past them.
Liebherr freezer working, refrigerator doesn't
Take the cover off the fridge fan and put a flash light in there and a camera set to record. close the door for a couple of minutes and then look at the footage to see if the fan is running. The circulation fan should run all the time.
4/5/2023 4:16:50 AM •
Liebherr...
Answered
on Apr 05, 2023
LIEBHERR CBNes 39560 Fridge - ice in the drainage trough on the back?
Question edited for correct spelling of the maker.
Question moved to maker category.
Check the temperature of the fridge with a digital thermometer. I should be 5' centigrade. It may be set too cold and freezing condensation running on the rear wall. Also make sure the circulation fan is working. It looks like it is the round disc at the top rear.
Push a flexible net curtain wire down the drain until it appears above the compressor pan.
You can also try cleaning the drainage trough, dry it and spray it with dry silicone spray or even WD40 if you don't mind the smell. That will stop water sticking.
https://mediamarkt.pl/agd/lodowka-liebherr-cbnes-39560
3/29/2023 5:02:00 PM •
Liebherr...
Answered
on Mar 29, 2023
Liebherr cnesf 5013 superfrost always beeping
Maybe it is only in the settings, I don't know the details of your ref but I would like to suggest to consult it in the technical experts.... because you said, it is turning on and off but it is working, maybe you only mistakenly click some button but if not, the refrigerator is the problem ( if it is new one, you can return it and replace a new refrigerator but in this case, you need to check it before replacing another one)
10/29/2021 4:02:51 PM •
Liebherr...
Answered
on Oct 29, 2021
