20 Most Recent
ASUS RTG32 Router Questions & Answers
Forgot asus RT-G32 router login
You must perform a factory reset using the reset button on the rear the device. You will then have to login using the factory default user id and password, create your new password, then reconfigure your router to your system as all settings were reset to factory defaults.
I need to reset my
You should call on (( +1-800-585-2494 )) Toll Free Asus and get help for Asus.
Basically I have just set
When you say it goes out. What do you mean? What are you seeing? Let me know and lets see if we can get ya fixed up.
How to reset my router ?
Pull the power plug. Unlike your PC, your router doesn't need to shut down gracefully.
There is computer lore that you should wait 10 seconds before plugging it back in, to let all the charge drain from the router's RAM, so I always do.
I have asus RT-G32 and it works max 10 mbit
its your ISP that limits you. you probably have a 54G connection between you and your router and a 10mbits connection to the internet. so, when you run a speedt test you show 10mbits...
your service is working fine...
and FYI: when you do a download and it says your downloading at 56k or something that has nothing to do with you or your ISP, thats how fast the person hosting the file can send it to you.
yup, the internet is one bottle neck after another!
I have got RTG32 router
Do you use a username and password provided by your ISP on the computer to connect to the internet? If yes, these need to be entered into the connection settings of the router. Are you connecting the internet line to the WAN port on the router? Did you install to your computer the ASUS utilities? Try the EZ Setup utility.
You can download the manual from this link
http://www.asus.com/product.aspx?P_ID=gEbdYWdf5mjkJUKc
