20 Most Recent
1Way Remote Transmitter Questions & Answers
How to program new remote to alarm
TRANSMITTER PROGRAMMING Note: System can learn up to 3 different codes max.
1. Turn Ignition ON and OFF 3 times quickly, leaving it ON the 3
rd
time. (ON/OFF, ON/OFF, ON) You should hear (1)
short chirp.
2. Push the Program/Override Button for 5 seconds until the siren chirps (3) times. Release the button.
The system is now in programming mode.
3. Press Button #1 on new transmitter - siren will chirp to confirm programming. Repeat Step 3 within 5 sec. for up to
2 additional transmitters.
4. Turn off Ignition.
Note 1: If only one transmitter is being programmed, continue pressing button #1 until dash LED flashes goes out and
the system chirps to exit programming mode to prevent unauthorized codes and noise from entering the system.
Note 2: Programming mode is exited automatically after 5 seconds of last code transmission or once 3 new codes
have been programmed. The LED will flash (4) times indicating program mode exit.
Crimestopper SP502 usb remote wont hold charge
If your Crimestopper SP502 USB remote isn't holding a charge, there could be a few potential reasons for this issue. Here are some steps you can take to troubleshoot and potentially resolve the problem:
- Check the Battery: Make sure the remote's battery isn't damaged or worn out. If the battery is old or not functioning properly, it might not hold a charge. If possible, replace the battery with a new one and see if the issue persists.
- Charging Cable and Port: Ensure that you are using a functional charging cable and connecting it to a working USB port. Sometimes, the issue might not be with the remote but with the charging equipment.
- Cleaning: Sometimes, debris or dirt can accumulate in the charging port of the remote, preventing a proper connection with the charging cable. Gently clean the charging port using a small brush or compressed air.
- Resetting the Remote: Try performing a soft reset on the remote. This might involve holding down certain buttons or combinations of buttons for a specific duration. Refer to the user manual for your Crimestopper SP502 for instructions on how to do this.
- Firmware Update: Check if there's a firmware update available for your remote. Sometimes, firmware updates can improve the device's performance and battery life.
- Contact Customer Support: If none of the above steps work, consider reaching out to Crimestopper's customer support for assistance. They might be able to provide further troubleshooting steps or suggest a solution.
- Battery Calibration: In some cases, calibrating the battery can help improve its performance. Fully charge the remote, then use it until the battery is completely drained. Repeat this process a couple of times to see if it helps the battery hold a charge better.
- Replace the Remote: If the remote is still not holding a charge after trying the above steps, it's possible that there's an internal hardware issue. In this case, you might need to consider replacing the remote.
Remember that the specific steps you should take may vary depending on the model of your Crimestopper SP502 remote and the instructions provided in its user manual. If you're uncertain about any step, it's a good idea to refer to the manual or seek assistance from the manufacturer's customer support.
Vehicle wont start with sp101 alarm
under the dash by the steering column you will see some wires that dont belong and a small black box about a inch square two wires will go up and into the steering column there will only be two that come from the box cut the wires that go to the box and connect them together its the starter disable . removing the blk box it should start
How do i reprogram my remote?
Sometimes if you press both remote buttons on a transmitter at the same time next to the vehicle for more than 10 seconds it will reprogramme a remote
Renault Megane is draining the battery over night,
I would have your alternator and battery checked after doing a simple inspection of all your power functions. If something is draining the battery fully overnight your battery may not be getting fully charged, or the battery may be old. If the vehicle only does city driving - then once a week you need to dive the vehicle at least 20 minutes of straight driving so the battery gets charged more than it needs for everyday operation of the vehicle.Simple inspection: Check all electronic devices from radio, tv, phone chargers, interior lights are working properly and fully shut off. If a switch is half way, example; interior lights set from "door to on" the light may not be on - but there is a slight draw all the time on the battery.Once we had our dashboard light on all the time but it was turned down so faint with the dimmer switch you could not tell it was actually on. It seems like a simple thing but it drove us crazy for two days until we discovered what was up.If everything checks out then you need to see a mechanic. One thing you can look for under the hood or dashboard is that all wiring is properly sheathed and there is no damage to the insulation around the wires. Again, have them inspect the alternator, (battery charging system), and the battery. An alarm system by itself should not be that taxing to drain your battery overnight.Best of Luck.
Intermitant car alarm problems on a 96 ford fiesta
I really don't think you have an immbobilizer, but if you are handy.. look behind dash at ignition harness try and find a blk/blu or grey wire, see if it is cut going to a relay of some sort, if so cut relay out and recoonect wires back together, see if car starts ....
Van alarm is draining battery flat over night
I doubt it is the alarm, but a simple way of checking is to unplug it.. look under drivers dash for an aftermarket box, unplug the connections (after charging battery) and wait till next day.. I think you might have a diff issue (I have installed these for over 10 years and never seen one actually discharge a battery)
Remote will not work now
if the ant. for the system was mounted on glass it may have been disconected or if it was placed near top of dash it could have been broke or pinched thats where i would start
2001 Cadillac Deville Northstar Engine thermostat location
4.6 Northstar V8. It is located on the rear of engine (driver side) in front. It is in the the water pump housing cover. Remove air box and intake tube and bottom radiator hose. 2 bolts(believe 10mm) on thermostat housing. These systems are a little finicky about air pockets....so fill slowly and let run at idle until operating temp and let cool and check level.....fill as needed and repeat if needed.
Peugeot expert central locking not working
A faulty central locking system might be due to several reasons, such as a blown fuse, faulty solenoid, or electrical wiring issues. Also, it's good to remember the fault might not be with the central car locking system but the key fob instead; over time, fobs require battery changes.
