20 Most Recent
9500IX Radar Detector Questions & Answers
Constant RPM engine static during
Most likely you will need to get a group loop isolator for it. I think escort sells one on their site. Or a good quality car stereo shop can get you one from Escort or PAC.
Escort solo 2 won't power on
cinnatti microwave corp will repair the unit if returned to them,seems as if the power cable got switched around and power was reversed to unit causing internal fuse to blow. the chg is appox $25 takes about two weeks
2001 Cadillac Deville Northstar Engine thermostat location
4.6 Northstar V8. It is located on the rear of engine (driver side) in front. It is in the the water pump housing cover. Remove air box and intake tube and bottom radiator hose. 2 bolts(believe 10mm) on thermostat housing. These systems are a little finicky about air pockets....so fill slowly and let run at idle until operating temp and let cool and check level.....fill as needed and repeat if needed.
Peugeot expert central locking not working
A faulty central locking system might be due to several reasons, such as a blown fuse, faulty solenoid, or electrical wiring issues. Also, it's good to remember the fault might not be with the central car locking system but the key fob instead; over time, fobs require battery changes.
What is hashtag
hash·tag
noun
(on social media sites such as Twitter) a word or phrase preceded by a hash or pound signand used to identify messages on a specific topic."spammers often broadcast tweets with popular hashtags even if the tweet has nothing to do with them"
the hash or pound sign (#)."Hunt mistook an @ for a hashtag while tweeting derogatory thoughts about him"
