20 Most Recent
Optoma MovieTime DV10 Multimedia Projector Questions & Answers
How do I get a disc out when it won't eject?
Unfortunately you can attempt to pry up lid at where it locks shut. Hope nothing cracks.. Use something plastic not metal .. make sure its powered off. Thats my best guess, Sounds like you have more than one disc inside?
Unable to Connect DV10
Hello!
Which are laptops? I use IBM R40e and HP laptop and I usually connect them with DV10 for conferrence. It's well! I have just a problem with Asus EEE. It unable connetc with DV10. I try use Video jack to connect. Result: It can display but the quality is very bad. Now I try to find another way to connect them together. Some information to share with you. Thanks you!
Where do you watch movie on a computer
The DV10 lets you connect 3 types video cables. VGA, Component, or RCA composite. Look at your computer to see what video outputs it provides.
If you Google VGA cable, Component, or RCA composite, you'll see what these cables look like.
I have the Optoma MovieTime DV10 Multimedia
Dear Sir,
Welcome to Fixya Support.We are Happy to assist you.
Your Projector temperature sensor could be faulty. So locate
the temperature controlling sensor and replace
it with new one. It will solve
your problem.
Best Regards
Chandrashekhar
Fan working
you must test the voltage terminal Fan, if there are the FAN is faulty, if there are NOT the problem is fuse, or loose or faulty connection to the FAN.
Merry Christmas
