I may be wrong, but I believe this is a cable problem somewhere between the video source and the projector. The loss of colour would happen if you are using COMPONENT AV cables and one of the video cables is damaged or not fully connected in the socket.
Component used 3 cables for video, usually coloured red, green and blue. If you remove any one of these 3 cables, you will get a black and white picture. As it's flickering between B&W and colour, this suggests a loose connection either at one of the sockets on the projector, or one of the sockets on the video source. There could also be a partial break internally in one of these cables.
I would advise you to check all the plugs are firmly in the sockets and, if possible, switch out the cables one at a time.
If this does not solve the problem, please let me know what the video source is and how it is connected to the projector. Please reply to me from within this page by clicking on "Add a Comment" below your question.
JustAnswerhttps://www.justanswer.co.uk > electronics > h66cm-n...
Jul 2, 2021 - Question - I NEED MY PASSWORDS RECOVERED OR COMPLEATLY, COMPUTER, BENQ, - . Find the answer to this and other Electronics questions on ...
1 answer · Top answer: Thank you for your question. My name is ***** ***** I look forward to assisting you. I'm ...
https://esupportdownload.benq.com > UserManual
PDF
Download Dual screen driver from BenQ website. 2 Surface Setup. 3 Camera Installation on Projector( please refer to corresponding PointWrite User Manual).
PDF
To link to the Projector Network Display System web page, click Link. 5. Disconnect. To disconnect from the projector(s), click the Disconnect icon.
https://www.benq.com > en-us > education > edtech-blog
1. Use a cable. The simplest, most common way to use Microsoft Office files on your BenQ Board is to connect your laptop using an HDMI or USB-C cable. · 2. Use ...
Sorry I don't really have an answer I had the same issue with a Sanyo I had to keep putting back the old lamp and getting it to start on that one then shut down and swap, eventually it worked, it was a pain. in the end I bought an led projector for the price of a new lamp for the old one
Presuming it is a Benq? Moved Question to Benq from Televisions category.
Lots of references to the section in the manual, but nothing to tell you how to fix it! Seems like it doesn't understand the date being fed to it. Contact Benq Support.
https://www.google.com/search?q=%22Scaler+shutdown+fail%22
Please include 'make model (what it is)', in all questions.
