20 Most Recent Apple iPad 16 GB 3G Tablet PC Questions & Answers
2answers
How do i sync my kindle account to my ipad?
install the kindle app, and when you log in with your amazon credentials, they will be synched
5/20/2022 5:47:15 AM • Apple iPad 16 GB... • Answered on May 20, 2022
How to unlock ipad 3
As for unlocking iPad, there are several ways you can resort to. Just follow one of them as below shows. If you've neither synced with iTunes nor set up Find My iPhone in iCloud, you'll need to wipe your iPad to factory setting to remove the password, which means you'll suffer losing all your data on iPad and get it as a new one. Please pay attention there is a slight difference in putting different models of iPad into recovery mode. iPad Air
  • 1. Turn off your iPad Air, press and hold the Home button.
  • 2. While holding the Home key, connect the USB cable to the device. Wait until the Apple logo appears and keep holding the Home button for few more seconds.
  • 3. Continue holding the Home button until the iTunes logo appears.
iPad mini/iPad pro
  • 1. Connect your iPad to your computer or laptop and open iTunes.
  • 2. While your device is connected, force to restart it.
  • 3. Press and hold the Sleep/Wake and Home buttons at the same time. Don't release when you see the Apple logo. Keep holding both buttons until you see the recovery mode screen.
Now you have entered the recovery mode, and 1. When you see the option to Restore and Update, click it. 2. Wait for the process to finish. Then you can set up and use your device. For more methods, check: How to Unlock iPad?
2/15/2020 12:30:49 PM • Apple iPad 16 GB... • Answered on Feb 15, 2020
2answers
Ipad A1396 is disabled it says to connect itunes but itunes does not connect or recognise it
This is a job for an Apple Genius. You will have to make an appointment online with a local Apple store.
9/7/2018 9:30:45 AM • Apple iPad 16 GB... • Answered on Sep 07, 2018
I have a turn off
That behaviour is strange. I've never seen anything like that happen and i've owned iPads from the first version on. I strongly suggest you make a last backup and then use iTunes to reinstall the iPad. It might be a good idea to start without using the backup and test if turning off is working as expected then. After that reinstall the iPad again and use the Backup you made first to have all your settings, apps and such back. If the problem returns it's in the backup ....
4/17/2018 10:06:26 AM • Apple iPad 16 GB... • Answered on Apr 17, 2018
2answers
How do I download showbox app on my ipad
Open Safari & go to URL https://itunes.apple.com/sg/app/showbox/id793056594?mt=8 bobwin
3/16/2018 9:48:34 AM • Apple iPad 16 GB... • Answered on Mar 16, 2018
3answers
How to connect ipad to my tv
You will need Apple Composite AV Cables to connect the iPad to your television. The cables can be purchased online or at your local Apple store.You can also stream your iPad to your television if you have an Apple TV by using Apple's Airplay.Hope that helps!
2/3/2018 6:26:15 PM • Apple iPad 16 GB... • Answered on Feb 03, 2018
Delete farm heros from Apple ipad
Push and hold the app icon until it starts to wiggle. You will see an X appear click the X to remove the app.
3/10/2015 10:45:04 AM • Apple iPad 16 GB... • Answered on Mar 10, 2015
IPad 1 won't update
For the iPad first generation (A1219) to update is only possible with connecting the device to iTunes on a computer. - this model supports only iOS 5 - no iOS 6/7/8 possible ! -------- ipad-1-update-qrl052hdp2kg0kvuqxssgusw-4-0.jpg ipad-1-update-qrl052hdp2kg0kvuqxssgusw-4-2.jpg ipad-1-update-qrl052hdp2kg0kvuqxssgusw-4-5.jpg
12/28/2014 9:01:42 AM • Apple iPad 16 GB... • Answered on Dec 28, 2014
How do i unlock forgot apple id password/icloud for a
The Apple ID is different from the iPad password, and is handled through iCloud. You may want to pursue this in Apple's help web site: http://help.apple.com/icloud/#/mmfc0f1a3b
8/18/2014 1:04:39 PM • Apple iPad 16 GB... • Answered on Aug 18, 2014
2answers
Forgot reset password
you can reset your iTunes password from the iTunes web site, and the associated em address. and restore the iOS device on your computer with the iTunes app
7/22/2014 5:23:15 PM • Apple iPad 16 GB... • Answered on Jul 22, 2014
How to delete kindle books from ipad
Simply access the Kindle library on your iPad (last screenshot here: http://iphoneappbackup.wordpress.com/2014/06/23/how-to-read-kindle-books-on-ipad/) and delete the books of your choice from there.
6/25/2014 9:28:43 AM • Apple iPad 16 GB... • Answered on Jun 25, 2014
2answers
Volume icon appears in the middle of my iPad 3 screen and won't stay off.
Do you have a case on the iPad? Sometimes an ill-fitting case can trigger the buttons by itself. If there is any lint or dirt between the case and the iPad, it can cause the same issue. If you have headphones with a volume controller on the cable - check that that is not being pressed by accident. You can also check to see if there is any lint caught inside the headphone hole. Sometimes that can cause a little electrical short and trigger funny behavior on the iPad. If none of those solve your problem, take it to the apple store, it could just be a faulty switch.
6/19/2014 12:43:55 AM • Apple iPad 16 GB... • Answered on Jun 19, 2014
Delete kindle books from I pad
GOTO SETTING/APPLICATION/AND UNINSTALL.
6/5/2014 12:01:50 PM • Apple iPad 16 GB... • Answered on Jun 05, 2014
I have a locked sim on my ipad
You need to contact the wireless carrier and they will give you a PUK unlock code.
4/9/2014 7:23:59 PM • Apple iPad 16 GB... • Answered on Apr 09, 2014
Ipad2 spanish manual
download from the ibooks app in spanish
1/20/2014 2:53:58 AM • Apple iPad 16 GB... • Answered on Jan 20, 2014
Ipad won't open
hard reset, press and hold both home and power button until it shuts off, your data is safe!
1/20/2014 2:52:22 AM • Apple iPad 16 GB... • Answered on Jan 20, 2014
How con i get dragon dictation on ipad from india
just use siri
1/20/2014 2:51:34 AM • Apple iPad 16 GB... • Answered on Jan 20, 2014
Apple iPad 16 GB 3G Tablet PC Logo
Popular Tags
112 questions posted
Top Apple Tablets & eReaders Experts
nexrad_chris
NOEL
NOEL
John
John
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
View Most Popular
iPad Apple
  • iPad Apple
Most Popular Question
delete farm heros from apple ipad
  • Tablets & eReaders
