20 Most Recent
Leica 13596010 Microscope Questions & Answers
How to get my microscope to turn on.
Richard:
Double-check the electrical source (plug) you have it plugged into with another device.
Just because the bulb "looks good" does NOT mean it IS good, also. If the electrical source ("the plug") is "hot", then the likely culprit is the bulb. Next would be the electrical switch - "fiddle" with it a bit.
(work it like a toilet that is problematic: jiggle the handle. wiggle things a bit. yell at it. whack it a few times)
If that doesn't work, check your warranty to see if a repair is covered.
(don't "whack it" so hard the warranty is void!)
Do we need to periodically calibrate the
Depends on the microscope. Generally, with most simple microscopes that are used often, calibration (aligning of the prisms, objectives and eyepieces) shouldn't be required more than once every 5 years or so.
We have got a leica
This issue could potentially be solved by a flatfield software correction of the camera that you are using. I would recommend visiting leica-microsystems.com and filling out a Contact Me request. Your local Leica specialist will then be in touch to help.
Need manual for Leica MZ16F
Tech specs and exploded diagram
http://www.clemex.com/pdf/brochures/Leica_MZ_16_Tech_en.pdf
Uusers manual
http://biotech.wku.edu/online_manual/Leica%20MZ16%20Fluorescence%20Stereomicroscope.pdf
Enjoy
AA-Spectrometer Unicam 939 Error
The error you are experiencing on your Unicam 939 AA-Spectrometer with the software reporting error 16 and 2, along with lamps 1,2,3,4, and 10 lighting up, could indicate a few different issues. Here are some steps you can take to try to fix the problem:
- Restart the spectrometer: Turn off the spectrometer and unplug it from the power source. Wait a few minutes, then plug it back in and turn it on again. Sometimes, a simple restart can fix issues with the instrument.
- Check the calibration: It is possible that the instrument needs to be calibrated. Follow the manufacturer's instructions for calibrating the spectrometer.
- Check the lamps: If multiple lamps are lighting up, it could be due to a problem with the lamp assembly. Check that the lamps are properly installed and functioning. Try replacing any lamps that appear damaged or worn.
- Check the power supply: Make sure the power supply is functioning properly by testing the voltage output with a multimeter. If the voltage output is incorrect, try replacing the power supply.
- Check the communication between the software and the spectrometer: Ensure that the software is properly communicating with the spectrometer. Check that the cables are properly connected and that the software settings are correct.
If these steps do not resolve the issue, it may be necessary to contact the manufacturer for additional support or to seek the assistance of a professional repair technician.
3/24/2023 6:39:35 AM •
Science &...
Answered
on Mar 24, 2023
Eppendorf centrifuge model 5702: lid not does latch/lock after emergency release.
If the lid of your Eppendorf centrifuge model 5702 is not latching or locking closed after the emergency release, it is possible that the locking mechanism is damaged or misaligned. Here are some steps you can try to troubleshoot the issue:
- Check the alignment of the lid: Make sure that the lid is properly aligned with the base of the centrifuge. If it is not, the locking mechanism may not engage correctly. Adjust the lid as needed and try to latch it closed.
- Inspect the locking mechanism: Check the locking mechanism on both the lid and the base of the centrifuge for any signs of damage or wear. If you see any damage, you may need to replace the locking mechanism.
- Check the safety interlock switch: The safety interlock switch is a small button located on the base of the centrifuge that is depressed when the lid is closed. If this switch is not working correctly, it can prevent the lid from latching closed. Check that the switch is functioning properly by pressing it with a small tool while attempting to latch the lid.
- Contact Eppendorf customer support: If none of the above steps work, you may need to contact Eppendorf customer support for further assistance. They can help you troubleshoot the issue and provide advice on how to proceed.
3/15/2023 4:55:19 AM •
Science &...
Answered
on Mar 15, 2023
