20 Most Recent
ION Audio Tailgater Portable PA System Speaker System for iPod Questions & Answers
No sound on the tailgater
My tailgater is from the US, and I live in NZ. I changed the voltage to NZ and while the unit did work straight out of the box, after a month of me not using it, it now no longer has any volume. I have tried all the knobs but thats as far as my knowledge goes! Does anyone have any solutions I can try? thanks!
4/26/2015 8:19:18 AM •
ION Audio...
Answered
on Apr 26, 2015
I bought the ION Tailgater
You should have no problems.
I live in Australia, with 240 VAC, and we see this type of thing a lot.
Put the cap back on once you have switched it.
I have seen a computer power supply that was accidentally switched back to 120 as the switch had no cover.
11/23/2013 12:14:57 PM •
ION Audio...
Answered
on Nov 23, 2013
How to remove the lead
Very Easy!!! i just replaced mine yesterday, In the bottom of the tailgater there is a cover plate with 4 screws. Unscrew them and pull battery out, unplug the positive and negative cables attached to battery. Take Battery to an Electronic Store and ask for replacement battery. These batteries are also used in back up home alarm systems so they're pretty easy to find. i found mine at radioshack. Now to install, easier!!! plug in power and ground cables to battery, slip battey back into pocket screw back on plate, and charge for good 4-6hrs. and voila!!! you'll be bumpin in no time!!!!
7/11/2013 6:42:57 PM •
ION Audio...
Answered
on Jul 11, 2013
I have an ION Tailgater
I just bought four units, 2 of them work fine but the other two have problem, but one of the unit did get charged up even without the charger light on. I switch on the unit, leave it plug in for a few days and the unit come back charged. I try with the other one, but it is not working.
10/4/2012 4:49:02 AM •
ION Audio...
Answered
on Oct 04, 2012
How to change the auxiliary input on an ion tailgater
Yo. This same thing happened to me. It sounds rudimentary, but I just superglued toothpicks onto the broken ends (obviously being sure not to get glue on the jack itself) and after waiting for them to dry, I just yanked them out by the toothpick. Worked like a charm. Good luck!
6/15/2012 4:16:45 AM •
ION Audio...
Answered
on Jun 15, 2012
The mic has died on
i have an apple i pod docking station Model A1121. It doe'snt want to
play whenever an ipod is attached to it. The lights are all on and flash
when pushing the volume button, buut no noise.
11/23/2010 3:08:27 PM •
ION Audio...
Answered
on Nov 23, 2010
