20 Most Recent
LG TU500 Cell Phone Questions & Answers
Free unlock code for LG tu500 phone
Hello:"""defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000Default 6 Digit Security code: 123456 or 000000Type *#06# at the mobile screen to know IMEI no of your mobile.send the IMEI no to me and i will reply you with unlocking code.IF Problem not Solved SoPlease New Software install in the Phone Problem will Solved
I need to unlock lg tu500 (locked to telstra
hello,the only person to unlock the phone for you freely is your service provider,all you need to do is just to call them and give them your mobile number and imei number.there are no free codes available for it now.
wish you good luck,
take care.
Need unlock code for TU500F
Make a call to fido and asking them for a
LG TU500 unlock code, they will ask your reason why you need that unlock code and takes some charge for that unlock code. Cost may vary depends on your mobile phones model approximately $60-$80. But you can get
lg unlock code with less price from third party sites.
I need my puk for a lg tu500f phone i am locked
A
request for a PUK code ("Personal Unlocking Key") will appear on your
phone if your SIM card PIN code is entered 3 consecutive times
incorrectly.
Your SIM card will then become
"PUKed" or Blocked. This is a security measure to protect your service.
You
need to call the Customer Service department of your cell phone
provider and they will give you the PUK code which will unblock your SIM
card.
My lg tu500 keeps saying
The phone's internal memory or "cache" is most likely corrupt. I would wipe to phone to factory defaults to reset the cache.
Lg fb163-how to add bluetoth function
To add Bluetooth functionality to your LG FB163, you can use a Bluetooth adapter that is compatible with the device. Ensure that the adapter you choose is compatible with the FB163 model. Once you have the adapter, follow the instructions provided with it to connect it to your FB163 system.
To connect your Android phone to the FB163, you'll need a compatible cable. Typically, you would use an auxiliary (AUX) cable with a 3.5mm jack on both ends. Plug one end into the headphone jack of your Android phone and the other end into the AUX input port on the FB163 system. Then, select the AUX input mode on the FB163 to hear the audio from your phone through system.
How can I hatd factory hard reset my LG 265 if I don't have my pin # nomore or forgot it .
- Turn the phone off.
- Press and hold the Power/Lock key (on the right side of the phone) and the Down Volume key (on the left side of the phone) at the same time.
- When the Factory data reset screen appears, release both of the keys.
- Use the Volume keys to highlight Factory data reset, then press the Power/Lock key to confirm.
- Use the Volume keys to highlight Yes, then press the Power/Lock key to confirm one more time.
- Your phone will perform a factory reset.
