20 Most Recent Vizio VF551XVT 55 in. HDTV Questions & Answers
Netflix keeps reloading while we are viewing. Movie will stop then screen indicates it's loading. At this point you have to turn the TV off and on and the movie will restart atbabout the point it turn
It almost seems that your internet speed is not fast enough. check you download speeds or if you can lower level of quality to standard.
11/19/2017 3:09:06 PM • Vizio VF551XVT... • Answered on Nov 19, 2017
Main control board
Cyclic resetting can be the protection circuit kicking in due to one or more of many possibilities. Some common failures which can cause self-protection: Insufficient ventilation/ cooling (overheat); Excess dust (arcing); Shorting components (overload); Open circuits (components, tracks or dry solder-joints); Incorrect load (eg speakers blown or loose wires).....
10/1/2017 11:44:33 PM • Vizio VF551XVT... • Answered on Oct 01, 2017
We have a 55" Vizio tv. the volume just started going real fuzzy tonight. the audio even completely stops. it does this on all channels and dvds. do you have any idea what the problem is?
check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Pull up older posts. Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts. http://electronicshelponline.blogspot.com/
10/15/2016 12:04:06 PM • Vizio VF551XVT... • Answered on Oct 15, 2016
Need service manual for vizio model vf551xvt/vf5521xvt
It will be difficult to get this document over net; because, they don't have their on circuit design. all of it are borrowed. Contact the authorized service centre.
12/25/2015 10:44:22 AM • Vizio VF551XVT... • Answered on Dec 25, 2015
TV Powers up, as well as all connected devices, however, there is no picture or sound. I can get the TV menu/cable guide to display
Fault at its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electro-medical.blogspot.com/ http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary .
12/9/2015 8:24:32 AM • Vizio VF551XVT... • Answered on Dec 09, 2015
My 55" vizio tv shut of and won't come back on. what can I do to fix it?
Fault in the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
3/2/2015 2:21:44 AM • Vizio VF551XVT... • Answered on Mar 02, 2015
TV Vizio VF551xvt. as you turn it on it "blinks" (the screen will turn on and off quickly). the logo stays white as if the tv was on but the screens stays off. how can I repair it?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/ Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
1/30/2015 3:32:54 PM • Vizio VF551XVT... • Answered on Jan 30, 2015
I replaced my power supply on my Tv. The new part I got blew out on me.
Did you replaced the power supply as card basis; or, repaired it by replacing any capacitors at it. If you have replaced the capacitors only, the polarity of the capacitor you've replaced might be reversed. Capacitors have both +Ve and --Ve polarities, and should match with the markings at the board; otherwise it will burst when you power it up. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
11/2/2014 12:45:50 AM • Vizio VF551XVT... • Answered on Nov 02, 2014
How do I connect my computer to my tv so I may
To connect your computer to your television, you will have to get the VGA cable for your computer and connect it to the back of your television, then you connect it to the inlet/port that is on the computer, that is the port where you connect your monitor, then you go to your television and select the AV mode, then you will be able to view your computers work on the television.
Take care and good luck
8/26/2014 3:07:28 PM • Vizio VF551XVT... • Answered on Aug 26, 2014
Screen split in half and then display overlaps
Main board fault. Contact any service technician, or the authorized service centre for Vizio. Gopakumar Gopalan Google
4/1/2014 6:51:24 PM • Vizio VF551XVT... • Answered on Apr 01, 2014
0answers
0answers
0answers
Red lite blinks vizio
Check its audio output card. If needy, repalce it as card basis.
7/25/2013 10:22:31 AM • Vizio VF551XVT... • Answered on Jul 25, 2013
Vizio VF551XVT 55 in. HDTV Logo
57 questions posted
Top Vizio Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
VF Vizio
  • VF Vizio
Most Popular Question
55 vizio tv shut come back fix
  • Televison & Video
