if these driver packages aren't right
http://download.cnet.com/2000-20_4.html
on the home page you should see a search tab just type in what you are looking for
you might have to search/try a few times to get it right
IE: motherboard name ethernet drivers or lan drivers
if you need more help with this post a replyhope this helps
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your (motherboard to your hard drive) make sure they have secure dust free connections and are not faulty or just replace them they might be faulty
if its a 40 pin flat ribbon type it will be the first to fail
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty
even something as small as a faulty electrical fan and its lead can cause you problems
computers need all power and data to continue through every working device and to have an end so any faulty leads will end up with a computer error
make sure your graphics card is securely seated with no dust built up or in the socket
if you remove your graphics check the socket to make sure its dust free
restart your computer then reinstall it this should activate found new hardware wizard
hope this helps
Ram is Random access Memory Ram is temporary memory your computer uses to store things you are working on for quick access later on Ram is faster than your hard drive so things you are working on are temporarly stored there so you dont have to waite while it loads The more ram you have the more programs you can have running at the same time you could either uninstall some of the programs running at the same time or stop them running until you need them if you right click in the bottom toolbar select taskmanager you will see whats running in application and processes you will see what is ticking overthat way you will no what is running and needs to be stopped or uninstalled if you see something running that should not be select end now
For the virtual memory follow these instructions:Right click on My Computerselect properties.On this screen select AdvancedClick the Settings button in the Performance sectionClick the Advanced tab on the Performance Options screenClick the change button
On the Virtual Memory screen, check if it is set to System Managed size
If so select custom and increase the size from what it is currently
For example if it is set to 512MB set it to 1024MBIf it is set to custom try setting it to System managed size You will need to reboot after making the change
hope it helps
60 questions posted
4,857 Questions
1,171 Questions
1,019 Questions
802 Questions
712 Questions
