20 Most Recent
Lenovo IdeaPad Y450 Notebook Questions & Answers
How do i change my lenovo latop from chinese to english?
Dear Costmer,
Go to the "Start" menu, then choose "Settings," "Control Panel" and "Regional and Language Options."
Click the "Languages" tab, then the "Details" button, the "Settings" tab and the "Add" button.
Choose an input language from the list. You can choose ANY language. For example, if English (US) is the "input language," check the "Keyboard layout/IME" box to select the US-International English keyboard from the list. Click "OK" and close the input window. A language indicator should appear in the System Tray (the area in the bottom right hand corner of the desktop). Switch between input languages by pressing the "Alt" and "Shift" keys simultaneously.
Click "Apply" to finish the process and finalize your choices. You shouldn't need the Windows installation CD for this process.
[email protected]
Bios password
This is supposed to be impossible, but there is a way to do it. Unscrew the case, locate the CMOS backup battery, remove it. Leave it out for a minute or so as to allow the capacitors enough time to discharge. Restore the CMOS battery to it's original position, screw the case back together, and power on the computer. Your BIOS password should be removed. Keep in mind that this will also restore all BIOS settings to factory defaults.
Intergrated webcam not working
In what? If you open the Lenovo supplied webcam software does it work? CyberLink ? Check Device Manager, Imaging Devices, is it enabled? driver up to date?
Lenovo y450 not shutting down
go to download.com and download ccleaner, this will clean out all junk from the hard drive, next download smart defrag from the same location and defrag the hard drive. Both programs should improve performance, next check to see how many programs start up when windows start, if there are to many it greatly slows the shutdown time and some cases stalls, remove any programs not needed.
Blue screen while gaming
Based on the error code, this issue has to dowith an external Hard drive working at high stress levels. Are you trying to run the games from a secondary HD? If so, try removing them and installing them on the primary HD.
Hi
My hard disk had crashed
Welcome to Fixya
You
need to enable it at the Bios. Reboot the computer and press the button
that will lead you to the BIOS menu of the motherboard. Go to System
configuration and go to actions keys mode. Press enter then select
"ENABLED". Save settings before you exit then test the issue.
Thank you for using Fixya! If you need further help, reach me via phone at
https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
My Fn + key is
it migt be turn off. try to press Fn + F1 + F2 + F3 + F4 + F5 + F6 + F7 + F8 + F9 + F10 + F11 + F12 to turn OFF or to turn ON. or you may go to BIOS to turn it on from there.
I have lenovo y450 ideapad,,i
Hi! Welcome to www.fixya.com.
Its best to call Lenovo and order the recovery disc so you can revert your system to factory settings by reinstallinng the right OS for your system with is a OEM version of lenovo. At the moment. You can check
http://support.lenovo.com/en_US/downloads/default.page? to get the the right driver for your system.
Hope this resolution fix the problem on your computer.
Thanks for contacting Fixya. God bless. Bye for now.
I cannot hear any sound
Check your laptop keys for symbols - usually printed at the bottom of the f keys. If your laptop has a FN button or something similar, you may have mistakenly disabled the speakers WITHOUT muting the sound in Windows.
