20 Most Recent
ASUS K50IJ-C1 Notebook Questions & Answers
DELL INSPIRON 1520 backlight or bulb
do you need bell laptop components?Pcpartsltd.com limited is a direct Exporter of high quality notebooks, laptop power adapters,
acer laptop batteries , laptop keyboards, laptop Inverters, laptop Hinges, laptop CPU Fan, laptop driver, laptop MotherBoards, Samsung Wall Mount, laptop LCD Bezel/ LCD lid, laptop lcd/led panel and Laptop LCD Video Cable. We are
Laptop Parts experts.
Black screen appears after start up
Try starting in safe mode. If things come up, then you may have malware on the system. I use 'SuperAntiSpyware' and find it to be a great remover of malware. It is free. I liked them so much I moved up to the paid version.
Craig
San Diego, CA
Asus delete password bios
PRESS the DEL key on boot up.... you will enter setup. Pending your computer .... it may be F1 or F11.... normally your shown what key to press at boot up (but the manufacturers (hide the on screen messages during boot up) so turn on this feature as well, because you get to see your system boot. Laptop and Notebooks have simple setups whereas more advanced motherboards like Asus give you a full array of options to control your PC.
Asus service manual
This is not the "Service Manual" but may help you service your machine - http://www.insidemylaptop.com/disassemble-asus-k-series-notebook/. It is instructions on how to take apart your machine and replace parts as needed.
Windows 7 os
Could be more specific? Do you want to install Win7 on your ASUS or what?!
I downloaded free cell on my tablet but can not find it
Go to settings - applications / applications manager (or similar) go to 'all' it should be listed, if not search again for the same game, if it is installed already there will be an option to open the application. Hope this helps and makes sense. if not post back
Restore factory settings
wen you notebook is prompt push F12 Function then start 4 or 5 wayform to start try start in second partion disk here stay the sotware to install it of catory or go to control panel and go to programs and then desintall many programs you not use and then go to hard disk propieties and then delete all the carpets with the name temp and you have more disk space
