20 Most Recent Sentry FIRE-SAFE Combination Safe DS3431, DS3431 Questions & Answers
Need to open sentry safe without key or combo
You might be wondering how to open a sentry safe without a key. Using two paper clips, make a tension tool and a picking tool. Place the first paper clip in the lower portion of the lock, then the second in the upper portion. Wiggling the other one while turning the first one clockwise. Turn the paperclips clockwise after pressing the pins three times.
6/6/2022 8:49:56 AM • Sentry FIRE-SAFE... • Answered on Jun 06, 2022
How to open sentry safe sfw123cs
Anon, Contact a local locksmith, most of them are skilled in opening small safes when code or key lost. Check the attached links,instruction and guides on how to open your safe. Good luck "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info." SFW123CS Combination Fire Safe http://content.etilize.com/User-Manual/1027349209.pdf How to open sentry safe sfw123cs Sentry FIRE SAFE Combination Safe DS3431... Emergency Locksmith Services Aim Lock Safe
1/26/2018 6:32:54 AM • Sentry FIRE-SAFE... • Answered on Jan 26, 2018
I have the combination, but I forgot the order
3 Digit Combination Lock
31-10-31
  1. NOTE: If your safe DOES NOT have a key, skip Step 3.
  2. Turn the dial to zero.
  3. Insert your key and turn it until the plunger pops out.
  4. Turn the dial to the left (counterclockwise) three times to the first number of the combination (pass the first number of your combination two times, stopping on it the third time).
  5. Turn the dial to the right (clockwise) two times to the second number of the combination (pass your second number once, stopping on it the second time).
  6. Turn the dial to the left to the last number (stop the first time on your last number).
  7. Pull the handle down; the door should open.
3 Digit Combination Locks for Security Safes
31-10-31
  1. Turn the dial to zero.
  2. Turn the dial to the left (counterclockwise) three times to the first number of the combination (pass the first number of your combination two times, stopping on it the third time).
  3. Turn the dial to the right (clockwise) two times to the second number of the combination (pass your second number once, stopping on it the second time).
  4. Turn the dial to the left to the last number (stop the first time on your last number).
  5. Insert the key; turn right.
  6. Pull on the key while it's in the lock to open the door.
3 Digit Combination Locks for Gun Safes
31-10-31
  5. Pull the handle down; the door should open.
Electronic Locks
31-10-31
  1. Insert the tubular key into the lock to the left of the key pad.
  2. Turn the key all the way to the right until the plunger pops out.
  3. Press the five-digit factory code. The green Proceed light will come on.
  4. Pull the handle down; the door should open.
4 Digit Combination Lock
31-10-31-10
  2. Turn the dial to the left (counterclockwise) four times to the first number of the combination (pass the first number of your combination three times, stopping on it the fourth time).
  3. Turn the dial to the right (clockwise) three times to the second number of the combination (pass your second number twice, stopping on it the third time).
  4. Turn the dial to the left (counterclockwise) two times to the third number of the combination (pass the third number of your combination one time, stopping on it the second time).
  5. Turn the dial to the right to the last number (stop the first time on your last number).
  6. Pull the handle down; the door should open.
You can find more information about your Sentry Safe at www.SentrySafeShop.com
3/7/2017 1:29:17 PM • Sentry FIRE-SAFE... • Answered on Mar 07, 2017
2answers
How to creeate a new combination for a sentry 1310 valueguard saf
Have a 1310 Sentry Valueguard safe and cannot remember the combination nor can i remember where i put the paper that i once wrote the combination down on....need help!
4/9/2016 2:11:35 PM • Sentry FIRE-SAFE... • Answered on Apr 09, 2016
I have lost the combination for my safe model V330 my model number V330 Sentry safe
  • Open your Sentry safe by typing the five-digit factory code (found in your owner's manual) on the keypad. It's always a good idea to change your combination while the safe is open, so that you don't inadvertently lock yourself out.
  • Delete any existing codes by pressing the "P" key and entering the factory code, followed by "00000." On older safes, press the "PROG" key and entering your factory code twice to delete old codes.
  • Press the "PROG" or "P" key again on your Sentry safe's keypad.
  • Enter your safe's five-digit factory code.
  • Enter a five-digit code of your choosing within 5 seconds. This is your user code. While the factory code cannot be changed, your user code can be changed as often as you like, and that should be your primary code to open the safe. Only you should know your safe's factory code.
  • Retype the user code to verify it is working, and then close the safe.
3/19/2016 10:08:48 PM • Sentry FIRE-SAFE... • Answered on Mar 19, 2016
3answers
How do I open my Sentry Safe when the batteries have gone dead?
Some safes come with a key to open it with when this happens.key hole is cancelled under or near the keypad...not sure if yours is one of them.or there maybe a slot to plug in a battery pack .good luck..hope I have helped.
3/17/2016 6:15:54 PM • Sentry FIRE-SAFE... • Answered on Mar 17, 2016
I lost my combination so i cant open.
Fitzroy, You can try and find a good locksmith in your area.
3/6/2016 5:20:19 PM • Sentry FIRE-SAFE... • Answered on Mar 06, 2016
Lost combination ..how to open
How to crack sentry safe, Lost safe combination - YouTube
? 5:43 https://www.youtube.com/watch?v=UdMun9qBgFo Sep 25, 2012 - Uploaded by George Serrano Lost safe combination Sentry Safe m# DS0100 Cracked! Still usable.
' Sentry® Safe ' DS3431 Combination FIRE-SAFE®
1/20/2016 9:37:07 PM • Sentry FIRE-SAFE... • Answered on Jan 20, 2016
0answers
2answers
S0409 lost combination
All you have to do is find your owners manual the sentry safe combination was posted in. Unless you locked it the safe as happens all the time. After all that is the safest place for it right. Or you can just call a locksmith service tech
11/9/2015 7:51:30 PM • Sentry FIRE-SAFE... • Answered on Nov 09, 2015
2answers
I need a default code for my Sentry safe
You will most likely need to contact them again and tell them what happened.
7/13/2015 7:10:02 PM • Sentry FIRE-SAFE... • Answered on Jul 13, 2015
The keypad has malfunctioned. how do I open my safe
You should have a key behind the name plate.
3/4/2015 9:44:27 AM • Sentry FIRE-SAFE... • Answered on Mar 04, 2015
The safe i have is locked with the door open. How do i reset the safe to close the door.
Remove the batteries end leave it for 10mins or so..then replace batteries and set a new combination on the lock.
2/24/2015 8:13:21 AM • Sentry FIRE-SAFE... • Answered on Feb 24, 2015
Sentry FIRE-SAFE Combination Safe DS3431, DS3431 Logo
151 questions posted
Top Sentry Home Security Experts
Grand Canyon Tech
Grand Canyon Tech
john h
ADMIN Andrew
ADMIN Andrew
Are you a Sentry Home Security Expert? Answer questions, earn points and help others
View Most Popular
  • Sentry Home Security
Most Popular Question
open sentry safe when batteries gone
  • Home Security
