20 Most Recent
Canon FS200 Flash Media Camcorder Questions & Answers
How do i get sound through my tv
You will need a 3.5 to rca ( RED,WHITE,YELLOW) , then select the input source video, 1,2 or 3 pending what tv you have , if you have no rca inputs and just a screw in cable input , you can buy a converter for around 20 bucks , good luck
How do I record without
go into the settings and switch to external mic and dont use the mic. or if you have an on off switch on the mic switch to off , its cumbersome but works. I have forgot to plug it in all the way and that too works gives you video no sound. you dont need a new camera , good luck
How do you change a file type on the canon fs200
I know it's probaly pointless in 2014 to post this, but all you need to do is rename the video file so that it has an ".AVI" extension (Google "show extension names on Mac" if you need to). The ".PGI" file is used only by the camera, and is not used for any type of decoding on other devices (meaning you don't need it, and should just delete them).
I put the memory card from my Canon FS200 video
You definitely have anti-virus installed in your system (Computer), As a result system prompted for SCAN & fix due to possible virus or worms found in your device (Canon), At the moment you click that "Do you want scan & fix canon", the system have cleared/deleted the virus or worm infected file, In the result you are unable to find the video files again or If it is there it will not run. I would recommend you to formate your Memory Card and then use it. There is no way to recover that video again.
Hope this will help,
Thanks..!!
WHERE IS THE SERIAL NUMBER OF CANON FS200
On the bottom of the camers on the battery door there is a sticker with some letters and numbers. The serial number is the first 12 numbers that are listed on the first 3 rows. No letters at all.
