20 Most Recent
D-Link DIR-615 Wireless Router Questions & Answers
Router just has an orange power light
Hi Challywags,
Normally if the router's power light is orange, red, or blinking there is problem with it's software/firmware. Or in some worst cases, it might also be a faulty unit already.
Here are things that you can try:
* Unplug it and wait for 1 minute before powering it on.
* Reset the router using the reset button. Note, this will restore the default settings configured in your router. You may need to reconfigure the router after doing this.
In case none of the solutions above will work, and none of these steps will turn the power light green I recommend that you contact the router's manufacturer for further troubleshooting. If the device is still under the warranty you will be able to get it replaced.
I reset my router
Are you referring to the network password or the security key or the wep key? It's usually located at the bottom of the router, it says WEP key...
Hope this will help... Your response is very much appreciated....
I am trying to get my D-Link set up for wireless
If you have a hard connection that is you have a cable to your router you can go to Dlink's site and watch the setup videos if you are not savvy with technical terminology.
there is also a site called Ehow that will educate an well as show how to utilize the wireless setup you have .
Please provide your model number , Operating system and more detail as to the issue you have so we can further assist you properly.
FIRMWIRE FOR DIR-615 REV M2
Usually you can login on your browser to you router and go to the management section to check for firmware updates and select that button and it will download and install the firmware. On some models, you have to go to the D-link web site and look for firmware updates for your router. Always check what you current firmware you have installed and check the version of your router modem hardware (A, B, C etc). Then you can manually download the firmware (usually in a ZIP file), open the zip file, and then using your browser connected to the router look for Update Firmware. You will have to go to where (folder) you saved the downloaded update and select that file. It is recommended that you update using a LAN connection and not a wireless connection.
I cannot log into dlink router, what is the generic pass code
If you have not set a password on it, then the default for most dlink products is User: admin and Password: admin.If you have set a password on the system then this will not work. You will need to reset the router. You do this by pushing in the reset button on the back of the router (usually with a pen or paper clip). Do this with the power on and hold the button in for about 30 seconds. This will reset the router to factory defaults.Hope this helps
How to get password
The final solution is a factory reset of your router. You can do a factory reset by logging into the router using you browser. Go to the settings and perform a factory reset
If you forgot the router password, you ill have to do a factory reset by locating a small hold on the back of the router and insert the tip of of paper clip for about 10 seconds while the power is on. The router will be reset to out of box status and then you can set-up form scratch.
I want to log in to my d-link 615 but don't know
Login in using your browser and go to the wireless settings and set-up a wireless password/key. Remember the key because each device will now need it to connect. You can also turn OFF Broadcast SSID and your network name will not be shown on anyone's device. You must remember the network name when using this method.
