20 Most Recent Canon CanoScan 5600F Flatbed Scanner Questions & Answers
0answers
I'm using MacOX10.9.3 and now I don't get any preview on my Canon 5600F scanner. Downloaded 5600F Scanner Driver Ver. 14.11.4a but no go. Any sollution?
Downloading a driver does not change anything. To be sure, uninstall the complete scan program and restart the computer. After that, reinstall the new canon software. Perhaps you even first install 10.9.4 on your mac. Succes
8/18/2014 2:09:36 PM • Canon CanoScan... • Answered on Aug 18, 2014
2answers
I loaded the slide tray
Solved - The inside lid shows how to properly scan a negative. REMOVE the white pad on the inside of the lid so the light will shine thru the negative.
5/16/2014 2:52:23 PM • Canon CanoScan... • Answered on May 16, 2014
0answers
0answers
Error code 21780 after pushing
Arrange film as per the instruction Manuel, please remove the bottom layer of the scanner cover .
9/13/2011 12:53:46 PM • Canon CanoScan... • Answered on Sep 13, 2011
Letter size documents not fully copied along edge
I have many years experience repairing Canon scanners so here is my suggestion for you.
In answer to your question, I would think its a setting in your software. Make sure your software is set to 8 1/2 x 11. Or a work around is do a prescan the dotted line you will see come up around your document drag the dotted lines to the edges of the document then scan you should now get a full image of your document. This is called cropping and it will work to upsize or downsize a picture or document.
I hope this helps you out.
4/1/2011 6:17:13 AM • Canon CanoScan... • Answered on Apr 01, 2011
After installing the drivers and
Hello hayduke247
You must absolutely make sure you are using the correct driver for the correct device :
Windows Vista / 7 :
http://www.usa.canon.com/cusa/consumer/products/scanners/film_negative_scanners/canoscan_5600f#DriversAndSoftware
Other Windows versions :
http://software.canon-europe.com/products/0010652.asp
To correctly delete a program , use a specific tool rather than the windows deleting program : Download free RevoUninstaller from http://download.cnet.com/Revo-Uninstaller/3000-2096_4-10687648.html
If all this doesn' t work , your device is defective , not your software .
Best regards ,
fanaudi
3/25/2011 2:34:01 PM • Canon CanoScan... • Answered on Mar 25, 2011
How can I scan Minox
By design the 5600F cannot scan negatives that are larger than 35mm. But for smaller ones it's relatively easy: just load them one at a time in the carriage and put a strip of blank 35mm film on top of them to steady them.
Later you will have to crop the image to get rid of the black border.
You can scan larger films, but that implies destroying the negatives: cut them in pieces to fit the carriage and then paste the image parts in PS.
1/12/2011 8:44:52 PM • Canon CanoScan... • Answered on Jan 12, 2011
Canon CanoScan 5600F Flatbed Scanner Logo
33 questions posted
old marine
old marine
ZJ Limited
ZJ Limited
View Most Popular
CanoScan Canon
  • CanoScan Canon
Most Popular Question
loaded slide tray
  • Office Equipment & Supplies
