20 Most Recent
Canon CanoScan LiDE100 Flatbed Scanner Questions & Answers
Internal error code 5, 202, 54
Perhaps you have forgotten to unplug the scanner before scanning? That's what happened to me. I kept getting different error codes, 5,202,63 or 5,202,52 or 5,202,54 and also a message that the driver was not in the TWAIN folder. According to the help file the problem might have been due to my nfts file system. I also tried downloading various new drivers. Nothing helped until I noticed that I had not unplugged the scanner!
Scan gear
internal error occured
code: 5,202,52
TO ANYONE READING THIS...I nearly took a hammer and smashed my Canon LIDE 110 Scanner cause I was so mad that it gave me this stupid error (5,202,52) no matter where I was connecting it and I thought it was done...THEN I just took another USB Cable (Like I have around 10 different USB Cables) ...AND IT WORKED! Try several USB cables before you give up on it...also don't start messing around with drivers and stuff, you could end up screwing up your system like I did...I hope this helps someone out there in the future with error 5,202,52 or 5,202,54, etc.Try at least 4-5 different USB cables before anything else..(If you want to know, I successfully used the USB cable with one of the fat black circle things on it (I think its for power or something), not just a straight usb cable. It's still a 5 pin USB cable however (Regular USB on one side, small 5 pin connecter on the other side))
Driver
Canon Canoscan LiDE 110 driver for scanner error
Please follow below steps .
- First, open the "Task Manager" by pressing Ctrl-Shift-Esc.
- Then click on the "Services" tab and look for the stisvc service, that is, "Windows Image Acquisition (WIA)".
- Look at the "PID" column and get the id of the related process.
- Then go to the "Details" tab and look for the process with that id, which will be one out of the svchost.exe processes.
- Click on that process by the right mouse button and select "End task".
- Then go back to the "Services" tab and restart the WIA service by right-clicking on stisvc and selecting "Restart".
Hope it helps and my solution is helpful !
I just installed my new
mbrindle is great!!!! Many thanks - I was just about to take it back as I thought the scanner was defective. Would never have thought i had to do that. Thanks!!!
My canoscan lide 110 QH7-4933-01
This is a well-known problem of CanoScan products but Canon never provide a fix for it. It occurs also with CanoScan 9000F: Code:5,202,54
Internal error occured
code: 5,202,52 after
