20 Most Recent Kenmore 3.5 cu. ft. Front Load Electric Washer Questions & Answers
2answers
Kenmore Super Capacity 3.5 error code E59
see the error code E59= E59 equals no tachometer signal for 3 seconds.This means that the motor is not signaling to the washer normally and may be caused by a variety of failures within the motor, basket or the control board. Generally speaking, the E59 error requires the service of a Frigidaire professional for resolution due to the technical nature of the ERROR.God bless you
5/17/2022 6:32:16 AM • Kenmore 3.5 cu.... • Answered on May 17, 2022
2answers
I have a kenmore super capacity 3.5 quiet tumble easy access frontload washer. I have tried it on every program and at the end of each cycle the light comes on showing final spin but all it does is dr
Try cleaning your pump filter and pump, if the pump is not working correctly the machine will sense this and flash warning lights. Good luck
3/25/2018 7:56:15 AM • Kenmore 3.5 cu.... • Answered on Mar 25, 2018
What is the sequence to get code to find out washer malfunction?
Press both the start and pause buttons together and count the beeps. Then the light above the start button will flash so count those. Example is 5 beeps and 9 flashes means error code E 5-9
12/15/2015 7:16:20 PM • Kenmore 3.5 cu.... • Answered on Dec 15, 2015
2answers
Washer washes, drains, won't spin but after
Plug off the mains. The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the drain pipe you see. The white filter cover is right in front. Get yourself a good plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully.
On some models the filter is located ‘inside’ the big hose from the bottom of the tub. This takes more time to clean. Check out your pump too, comes after the filter; there could be anything clogging the impeller.
Check motor brushes, if less than one centimetre long, replace.
2/2/2015 2:38:32 PM • Kenmore 3.5 cu.... • Answered on Feb 02, 2015
2answers
My washing machine stopped mid cycle and won't drain or spin
What is the complete model number of your unit?
8/12/2014 3:17:11 AM • Kenmore 3.5 cu.... • Answered on Aug 12, 2014
How to fix a front load kenmore washer that won't spin?
Look under the machine There may be a service & troubleshooting manual in a bag, taped inside it
8/10/2014 4:11:57 PM • Kenmore 3.5 cu.... • Answered on Aug 10, 2014
417-48112701 won't spin
If there is still water in the tub, you may have something stuck inside your drain pump. The hose coming the bottom of the tub to the pump has a cup inside of it that will catch items left inside clothes. If youd can remove water, remove hose and clean the cup inside. Reinstall and that should correct the problem.
6/28/2014 2:09:19 AM • Kenmore 3.5 cu.... • Answered on Jun 28, 2014
I have a kenmore front load washer 3.5 capacity that won't spin
OK...I get it! It won't spin...Because it's A Ful of water! OK? You need a New Drain Pump! Here..watch on YouTube https://www.youtube.com/watch?v=ShGxY-U5uKg If you need further help, reach me via phone at https://www.6ya.com/expert/steven_b77d19396bfe2249
3/15/2014 8:11:12 AM • Kenmore 3.5 cu.... • Answered on Mar 15, 2014
Washing Machines Logo
237 questions posted
Alexander
vince
View Most Popular
  • Kenmore Washing Machines
Most Popular Question
washer come when start button
  • Washing Machines
