20 Most Recent
LG enV3 VX9200 Cell Phone Questions & Answers
Is there a way to recover deleted files from my sd
First of all, do not save any new file to the memory card.Take out memory card, and connect it to computer using a card reader. You should see memory card shown as a drive letter (like H:) in Windows Explorer.Download this
card recovery software called asoftech photo recovery, which recover not only photos, but also videos and audio files from sd card.Install and open asoftech photo recovery software, select the memory card, and click 'Start' button.
The internal screen on my
Dear dancingmonke,
I have had that happen to me a few times, and so far, the problem was the battery was dead, and had to be replaced with a new one. God bless your efforts.
EnV3 Internal screen messes up. The image jumps,
You are experiencing a hardware failure in the phone video.
If it does this all the time, a phone repair store may be able to help you. Knowledge of the connectors and/or electronics inside the phone would be required to diagnose the issue remotely.
Please wait screen
This sounds like a data corruption issue.
If you can delete and replace the music application, that should get it working again. You will have to rebuild your lists/folders, but the music files will be fine.
This is the price we pay for inexpensive, low quality software.
My baby through my phone at the wall and the
It deoends upon how much is your cell phone damaged . If your cell phone is not much damaged then it can be fixed otherwise you will have to buy a new one . If you are buying a new cell phone then I reccommend you to buy a phone which is unbreakable . Such kind of cell phones are made by Samsung .
My phone is stuck at
soohyungi Hi it sounds like the phone was doing a software update and it crash . You may be able to get it working again by taking out the battery but not put back on the phone, Plug the phone into the charger. Next I need you to look at the contacts on the phone see if they have any corrison on them. Now take a clean tooth brush one that hasn't been use. CLEAN the contacts and the charging port area . See if there is any dirt in the phone.If you can't get the phone to work go to a verizon corp store and let them take a look at it for you . Software crashes ocurr when thwe phone is in the middle and someone calls you . Hope this helps I’m happy to help further over the phone at
https://www.6ya.com/expert/ronald_e152e07e272e4f27
