20 Most Recent
HP EliteBook 2730p Tablet PC Questions & Answers
Slow running my tablet
remove unwanted applications, also the ones you dont use, reboot the tablet once, if still no help, download cleanmaster app its very nice
Rotate screen ipad lock
swipe up from the bottom of your screen, the button on the top right is a screen rotation lock, un click or click as needed for a screen rotation lock
Cursor jumps to corner of screen, is erratic
have you tried a usb mouse ?? as if that works it will be the touch pad is playing up. you can disable it and use a wireless mouse or usb one. as it would be cheaper then replacing the touch pad.
Hp elitebook 2730p I left
Either your laptop had gone to sleep or hibernate mode. You can set the timers under Power Options on the Control Panel for the laptop to go on sleep mode or hibernate mode if idle for span of time.
You can wake up the laptop by touching the touchpad, pressing a key or pressing the power button.
However, if above options will not work, the only option for you is to press and hold the power button for at least 5 seconds to completely turn off the unit. Try to power on the computer if it will boot up okay.
***ADDITIONAL NOTES FOR CASE TO CASE BASIS**
If you still get black screen, remove the battery and the ac adapter (charger) then press the power button for at least 20 seconds to discharge power in the motherboard. You can now reinsert the battery and power on the system normally.
***NOTE: If the computer will not boot up, the LCD or the motherboard might have failed.
Hope this helps.
I have an Italian CD
It is a different region so it may not be compatible. There may be some software which will support different region CDs. Try googleing "how to play different region CDs".
The battery light blinks after shutting down my hp
The same thing has been happening to my tablet lately, as well. However, on mine, that corner of the computer is slightly damaged (from shoving it into my backpack too roughly, i guess). Is your hp damaged? Otherwise, it's probably a hardware problem.
When i switch to tablet mode i have no keyboard to
There's an on screen keyboard available! XP: http://www.microsoft.com/windowsxp/using/accessibility/oskturnonuse.mspx Vista: http://www.microsoft.com/enable/training/windowsvista/osk.aspx The Windows 7 Flavor is available through the Ease of Access Panel just like Vista. This might help out a bit.
