20 Most Recent
LG Xenon GR500 Cell Phone Questions & Answers
PUK Blocked? What does that mean?
The PUK & PIN codes are Security Codes that are on the SIM card. PIN( Personal Identification Number ) PUK ( Pin Unlock Key). when the PIN code in entred wrong the SIM automatically Blocks the PIN. to unlock the PIN you need to Enter the PUK. but if you enter the PUK wrong the Entire SIM is Locked.
The PIN Code & the PUK codes are Only Known by your Network Provider. you have to get in touch with them to get the codes. how ever if you have PUK blocked you will have to get a replacement SIM
The touchscreen no responds
Try going into settings and go back to factory default,See if that resets your phone (but make sure you back up your contacts just in case you lose them.
Problem connecting Xenon to PC Suite II
And the PC in question has a bluetooth adapter? Sounds like its getting to the point where it would detect and connect after clicking finish then not finding the bluetooth adapter to connect to the phone. Another thing you can try is connecting via USB cable to the computer, that will get everything detected and install drivers as needed, then go back to trying via Bluetooth, my Motorola phone required doing that for some reason!
My phone keeps saying service
Hello, friend! I happened to see you with this problem, I also meet this error about my cell phone, I get many help from this forum, and also bought many DIY repair tools from china supplier , and vipprogrammer help me fix this error. maybe you can try it.or contact ther WhatsApp:+ 8615986801289 website:
http://www.vipprogrammer.com. They've solved my cell phone problem and I hope it will help you with your mobile phone trouble.
They are free to consult, I hope that the programmers I recommend can help you.
How to unlock the lg xemon (instructions)?
You can Unlock the LG XENON GR500 model Phone using the Unlock code,You can get the Unlock code and instructions from here
Classicunlocking.com and Unlock it from Network Lock....
LG GR500 Xenon Unlocking Instructions
Warning : Do not enter
any wrong unlock codes on your LG GR500 Xenon mobile phones. If you
enter over a certain amount of wrong unlock codes on your LG GR500 Xenon
mobile phone, your phone may get hard locked and sometimes become
unusable.
1 - Switch on your LG GR500 Xenon with a NOT ACCEPTED* SIM Card.
2 - LG GR500 Xenon will display "phone restricted" Select "Cancel".
3 - LG GR500 Xenon will display "phone restriction code" Enter the Unlock code. Select "OK".
4 - The handset is now successfully unlocked.
*NOT ACCEPTED : We mean, to use a sim card from a network other than the network your LG GR500 Xenon is locked to.
(OR)
1 - Switch ON your LG GR500 Xenon with its ORIGINAL SIM Card.
2 - Enter2945#*9701#.
3 - A menu will pop up, Select Sim Unlock.
4 - Enter your Unlock Code and press OK.
5 - The LG GR500 Xenon will then reboot and the unlock is complete.
ORIGINAL: We mean, to use the sim card that was originally given to you by your network/service provider along with the LG GR500 Xenon.
(OR)
2 - Type *#865625#.
3 - Enter the unlock code twice.
4 - LG GR500 Xenon should say: Network Lock Deactivated.
5 - LG GR500 Xenon may automatically reboot and is now unlocked!
Hi i just got this
Contact you're cell phone provider and see if there is a known issue or its a faulty phone.
