20 Most Recent HP Compaq Presario F500 F700 and G6000 Motherboard - 442875-001 Questions & Answers
3answers
How do i unlock my compaq presario f700 laptop
See this article. You may have to contact HP support or take it to an HP authorized service center.\
Sorry, those passwords are there for a reason.
Make a list and keep it somewhere safe away from your computer, where you can refer to it in need.
3/19/2024 3:47:49 PM • HP Compaq... • Answered on Mar 19, 2024
Compaq Presario F700--the display on
no photos, no joy why post lacking the look, as your topic is all 100% Look. a 2007 note book the year or close to the year they made Nivida chip solderball , GPUs, that all fail. so if its got that its, doomed, and buy 3 more used mobo and all doomed sure the screen is just a LCD screen and a backlight if the digital data to it is bad (GPU) then the GPU is bad. and hits soldered down,,, buy desktop next time, and its child's play fix. pop a new card or and HP 9540w, that has cards !@!! and dont FAIL.
10/26/2017 3:01:14 PM • HP Compaq... • Answered on Oct 26, 2017
I have a compaq presario f700 it have a problem
Compaq Presario f700 NOTEBOOK. first off im amazed it can even blink bark or glow at all laptop are scaled in DOG YEARs. my first guess is the not tried yet, exernal VGA jack works so only your screen is bad. as all are now with CCFL lamps dead or its power pack. called "inverter" the lamps go dim, yellow ,flicker then die, all do if CCFL best is upgrade top LED laptop and w7 and newer OS. the BIOS pages must work or the screen is bad seems power is ok, to me. and you. it came with VISTA. year 2007? im reading your service manual now. and see this? that is CCFL lamp not LED> this is bad or the inverter card that drives is is bad if BIOS FAILs to show in the screen, My best guess, no tests by me, testing is the only sure way to fix problems not guessing. why not get tech to fix it? capture-1z31dkbg41o2owghj0fas5br-1-0.jpg http://h10032.www1.hp.com/ctg/Manual/c01095493
7/20/2017 2:28:13 PM • HP Compaq... • Answered on Jul 20, 2017
Compaq Presario F700EM Notebook PC downgrade XP
Windows XP is pretty old now and not supported by Microsoft with updates. You may want to consider purchasing Windows 10 to install on your computer and/or purchasing an entirely different laptop.Software Empire The 1 Source For Affordable Software Downloads You may be able to use the Windows Vista drivers, as it does not appear that HP offers drivers for Windows XP. Compaq Presario F700 Notebook PC series Software and Drivers When downloading drivers, its best to only download them from manufacturer websites. For example, you may be able to download drivers separately from each device manufacturer: NVIDIA Drivers: http://www.geforce.com/drivers
5/19/2017 5:09:06 PM • HP Compaq... • Answered on May 19, 2017
My hp compaq presario f700 says no audio output device is installed. just installed windows 7. please help
go to hp support then download windows7 drivers ok jim
9/3/2014 6:48:31 PM • HP Compaq... • Answered on Sep 03, 2014
My HP Presario F700 recently started showing a recource conflict on motherboard while starting up. In addition the DVD-drive is not recognized even it does a self test. Any idea?
there might be 2 problems that come first in mind 1: due to long time pc explotation bios battery died 2: bios reseted and all divices become masters firs test battery voltage ir its good try to change bios boot up log
7/30/2014 8:51:34 AM • HP Compaq... • Answered on Jul 30, 2014
0answers
Hp presario f600 boots and runs but screen wont cut on
Well if you are sure the computer is running, then you could have a bad inverter, take a flashlight and shine it on the screen, if you see the icons and computer booting, then you have a bad inverter, go on amazon and order another LCD. also if you have a desk top monitor, connect the monitor to your laptop, then boot up your laptop, hold down the "FN" (function) button and press "F4", you should see everything on your desktop monitor. Good luck.
5/7/2014 4:09:11 PM • HP Compaq... • Answered on May 07, 2014
Can I load Xp over vista on persario f700
Yes and no, Yes because XP is an upgrade from windows vista Now!, but not today, because of marketing reasons, they are pulling support from XP, and you will have big problems registering you product code. Not to mention, they are not providing updates for XP anymore. There are ways to register your product code into your motherboard yourself but that's beyond my skill set.
5/7/2014 3:51:35 PM • HP Compaq... • Answered on May 07, 2014
How do i id my motherboard
hp web site support area download manual from them there
4/14/2014 9:25:42 PM • HP Compaq... • Answered on Apr 14, 2014
Password to compaq presario f700 laptop
What operating system? You may need to reinstall windows
4/10/2014 3:53:06 PM • HP Compaq... • Answered on Apr 10, 2014
How to id motherboard
Most of the time the model number is printed on the board itself near the CPU or beside the RAM slots. If your model number is not there you can sometimes also find it on the back side of the board itself which requires you to take the board out of the PC entirely. Usually if this is the case the model number is printed on a sticker on the back of the Mobo
3/24/2014 9:23:09 PM • HP Compaq... • Answered on Mar 24, 2014
Not booting hp presario f700
hit the f5 key then follow the screen from there that is in safe mode
3/24/2014 4:36:42 AM • HP Compaq... • Answered on Mar 24, 2014
No streaming sound f700
Look in the control panel for audio manager make adjustments there.Terry
3/18/2014 3:28:07 PM • HP Compaq... • Answered on Mar 18, 2014
Battery/charger
Charger go true a lot of power voltage regulators and in the end is not powerful inought to power loptop without battery, same capasity neaded to help maintain stable curent.
2/18/2014 7:00:36 AM • HP Compaq... • Answered on Feb 18, 2014
Laptop runs on battery and charges ok,but wont run just on the charger-hp f700
2/18/2014 6:59:13 AM • HP Compaq... • Answered on Feb 18, 2014
2answers
How to factory restore my compaq presario f700
It depends on which OS and software came with the computer and the state of the computer. (In all cases do not use the Microsoft System Restore. This will return a computer to the last known good state (revert to a prior version of the registry) but not to the factory installed state.)
To do a recovery without starting Windows:
Some Vista and Win7 machines came with HP Recovery Manager. Press F11 during bootup (BIOS prompt) then if the hard drive is accessible, the Recovery Manager will start. Follow the on-screen directions. (If you changed the OS from originally installed version or repartitioned the drive, this is not available.)
For all other OS and recovery software options, you will need an external (USB) optical drive. The preferred option is a R/W DVD drive to create the recovery media yourself. (HP will send you recovery discs for a fee if the machine is under warranty.)
If you can enter Windows, click Start
12/3/2013 6:19:00 AM • HP Compaq... • Answered on Dec 03, 2013
How to protect the vj card from over heating in presario f500
Walmart has a laptop cooler for about 20.00usd It sits under the laptop plugs into a usb port 2 fans run.Terry
10/19/2013 5:29:12 AM • HP Compaq... • Answered on Oct 19, 2013
The power light just blinks along with rest of them on ac power
Could be a bad battery. You could take the computer along with the battery and have it bench tested.Terry
10/19/2013 5:27:29 AM • HP Compaq... • Answered on Oct 19, 2013
HP Compaq Presario F500 F700 and G6000 Motherboard - 442875-001  Logo
321 questions posted
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • HP Computers & Internet
Most Popular Question
compaq presario f700 problem
  • Computers & Internet
