On the tv remote look for Mode Select, move switch to TV then "03" then press enter. Then pick up cable remote make sure the "cable button lights up ( by pressing on cable button at top) then you press guide...Voila!
0286,0288,0281,0284.
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order.Pull up older posts. Surf the site with patience. http://remotesearch.blogspot.com/http://electrohelponline.blogspot.com/
I have a Toshiba DVD Video Player/video Cassette recorder - the problem is that when I set the VCR to record for an hour it will record for less than that hour and eject the tape. Help!
Cable box have HDMI port,hook it up on a HDMI cable to the tv,will improve picture quality greatly.Tries HDMI cable to hook up the PS3 system and go in setup changes to HDMI setup will get HD format picture,will be very clear no more grainy and inconsistanty.
Check the power lead if it is fully plugged in, and if it still does the same thing it could be internal
problem. If the set is still under guarantee then let them to worry about it.
Less than a year old tv.Ur tv still have the manufacture warrenty.Look in ur owner manual,call the tv manufacture 1-800.... numbers on the owner manual.Talk to their customers service department,what locations or what shops they hire to call,to take care their product that still in warrenty.
if you do not have the directions. first manually turn on the set. then i find the code button. it may not say the same thing but it will be similar in words. push code, then push tv, then repeatedly push power until the set goes off then find enter(or something similar). this is an automatic code find technique.
You're better off just replacing the TV because of cost. If it is still under warranty why not contact the dealer you bought it from for an authorized service center location.
JustAnswerhttps://www.justanswer.com > TV Problems
Sep 28, 2018 - Can't get video to work on tv. Sansui HDLCD19WB and not sure of age trying to hook up PlayStation. Menu works, no just - Answered by a ...
1 answer · Top answer: Okay, that is likely the problem here because HDMI will not convert directly to AV red, white ...
