20 Most Recent
Polaroid TLA-01901C 19 in. LCD TV Questions & Answers
My Polaroid Flat Screen Model
This sounds silly but is your cable securely plugged into the back of the TV? This sometimes comes loose, I know mine does! make sure that it is seated properly and try again! Post back if this does not solve your problem!
9/4/2011 3:12:56 AM •
Polaroid...
Answered
on Sep 04, 2011
I have a Poleroid 19 inch flat screen. I turn it
The tv have 1 or 2 long boards call the LCD inverter boards.These 1 or 2 long inverter boards are dead.That why the LCD screen not getting a backlight to produced a picture.Replaced those 1 or 2 long LCD inverter boards,will get a baklight back and have picture.Tries websites like Shopjimmy.com,Ebay.com buy those refurbishes 1 or 2 long LCD inverter boards for the replacement.
8/18/2010 12:58:06 AM •
Polaroid...
Answered
on Aug 18, 2010
Tv won't change channels
Are you set to view through the antenna input. If you are on any other input say watching though your cable box your channel button for the tv is not usable. You are using the tuner in your cable box.
11/1/2009 6:35:10 PM •
Polaroid...
Answered
on Nov 01, 2009
Polaroid TV working with constant red flashing light
If your Polaroid Roku TV is working fine but the red light is continuously flashing, it could indicate an issue that may need attention. Here are some steps you can try to troubleshoot the problem:
- Power Cycle:
- Turn off the TV and unplug it from the power source.
- Wait for at least 5 minutes.
- Plug the TV back in and turn it on.
- Check Remote Control:
- Ensure that there are no stuck buttons on the remote control. Press each button to make sure they are not stuck in the pressed position.
- Update Firmware:
- Check if there is a firmware update available for your TV. You can usually find this information in the TV's settings menu.
- Reset to Factory Settings:
- Perform a factory reset on your TV. This will erase your settings, so be sure to back up any important information first.
- Check for Physical Obstructions:
- Make sure there are no physical obstructions around the TV, particularly around the infrared sensor on the TV and the remote control.
- Contact Customer Support:
- If the issue persists and your TV is still under warranty, consider contacting Polaroid customer support for assistance. They may be able to provide additional troubleshooting steps or offer a solution.
- Professional Repair:
- If the TV is no longer under warranty and the issue persists, it might be advisable to consult a professional technician or a TV repair service to diagnose and fix the problem.
Always refer to your TV's user manual for specific instructions related to your model. If none of the above steps resolve the issue, it's recommended to seek assistance from the manufacturer or a qualified technician for further diagnosis and repair.
12/27/2023 10:15:57 PM •
Polaroid...
Answered
on Dec 27, 2023
