20 Most Recent
Giorgio Armani Emporio Armani watches AR0315 AA Watch for Men Questions & Answers
The second hand will not re-set to zero. It has
This is a symptom of what is usually several possible issues:
1) The most common is that the battery must be changed. Insist on Energizer batteries only (as they do not leak) and visit your local Certified Master Horologist for assistance in changing the battery and resetting the watch.
2) The movement must be serviced every 3-5 years by a qualified professional. Dust and debris can cause the symptom of stopping and starting the movement. If you have owned it for less time than this, remember that the watch may have been manufactured and in the retail location longer than this period of time before it was purchased.
3) The movement is defective or damaged. If the watch is under warranty, and it was purchased through an authorized dealer, Armani will take care of this issue for you at no charge.
To properly assess this issue, I recommend taking the first step, as a CMH also has the proper tools to test the movement and battery to determine the best next course of action.
watchandpen
After replacing battery can't get the backplate of AR0156 back.
If you cannot snap the back on with your fingers the only safe way to get the back on again is to use a watch press. This is an expensive tool that most jewelers will have. I strongly recommend you take it to a jeweler (may want to call first to make sure their company will do it because most chain stores will not work on most brands). They should not charge you.If you are determined to do it yourself then you can try wrapping a wide pliers with duct tape or cloth and applying pressure on the front and back of watch to pop it on. WARNING: this is very dangerous for your watch. DO NOT apply pressure to the crystal, try to put the pressure on the stell lugs instead...
