20 Most Recent
Brother Personal FAX-190 Questions & Answers
When I send a fax the recipient tells me it comes thru black & unreadable.
Dear
The fax machine has ADF roller on the top of scanner, foun at the bottom of the fax when you open the top cover.
Pl. do clean the whit roller with lint free cotton cloth dampen with mild soap(care to be taken not flow the liquid inside.),
If still problem persists contact service centre to replace the CIS (rare).
Thanks.
Won't turn on
I also have a 190 that doesn't work, and I like to fiddle around with these things, so would you be interested in selling yours to me ? mike @
[email protected]
Plugged in-- no display/?
I also have a brother 190 that doesn't work. would you be interested I selling yours, because I like fool around with these things and maybe between the 2 I can get one working
[email protected]
It says document jam and there is no jam how do i
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you.
Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Brother personal fax190 paper jam
- Turn off the printer.
- Remove any paper trays. Inspect them for wrinkled or damaged paper.
- Also open the back cover of the printer if this model has one.
- Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
- If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
- If you find a piece of jammed paper, remove it by
holding it with both hands and pulling firmly. The goal is to keep the
paper from tearing. If several pieces are jammed together, try pulling
out the middle piece first to loosen the jam.
- If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do
this step especially if the jam message comes up repeatedly without any
obvious paper jam, there may be a small tear of paper inside.
- Ones the printer is free of paper Replace the toner or
ink cartridge and paper trays, close any doors you opened and turn the
printer back on.
- If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
- see alternative if the problem is still not solved.
alternative :
Load
a piece of thick paper, for example photo paper and press the resume
button (may be diffrent button on diffrent models) a few times to the
printer picks up the paper and puts it through the machine.
