20 Most Recent
Brother ES2000 Computerized Sewing Machine Questions & Answers
The tension dial does not
That is called bird nesting or thread nesting and is usually caused by the top thread not being fully seated in the tension disk.
Remove the top thread from the machine.
ALWAYS RAISE the presser foot and rethread from the beginning.
Start out with the top tension set at the midway point and then adjust it.
I have a Brother ES-2000
Sounds like the machine may have a timing issue, ie the needle is arriving at the bobbin at the wrong time. Be sure you are using a brand new needle as a bent/damaged needle is out of alignment and could hit the bobbin. If a new needle doesn't solve the issue, then you need to take it for repair. Or you can search for multiple web sites and videos that discuss sewing machine timing.
How do i thread the machine?
Hai, I suggest, easy way you go to near by local shop experience tailor , learnt how to thread the machine with in one hour or one day.
What does error E6 mean?
It's locked up because of a thread jam. See this page for more info. http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faqh/000000/000000/000068/faqh000068_000.html?reg=us&c=us&lang=en&prod=hf_es2000teus
E1 error code.
The pressure foot was up instead of down when I tried to run the machine without sewing something.
Not sewing
Check your manual for the error messages and what needs to be done.
If you do not have the manual, check the Brother website for a download.
The neddle is hitting the
Check to see if the needle is bent. If that is not the case you need to adjust the needle position on the needle bar. This may be something that you want to have a technician do, so you don't change the timing on the machine.
