20 Most Recent
Baby Lock Imagine Questions & Answers
Sews too fast
Have actually solved the problem now. there is an on line page which describes pulling the foot switch apart and adjusting the speed control slider for a BabyLock Evolve machine and this solution worked perfectly for the Imagine despite dire warnings from the importer not to do this.
Babylocker
8/10/2015 2:21:07 PM •
Baby Lock...
Answered
on Aug 10, 2015
Left needle on baby lock serger "imagine" skips
Change needles if they have done a few hours. Ales use ballpoint if seaming stretch fabrics.
Also you can get EL 705 needles, which have a longer scarf (groove at back) which helps with the loopers catching the needle thread. Or SUK is the stretch type with this longer scarf
Also if you are using cheaper thread cones, try a better quality with smoother finish and consistent weight, this will help too.
However if this doesn't resolve issue, your looper timing might need adjustment.
3/3/2015 8:36:13 AM •
Baby Lock...
Answered
on Mar 03, 2015
Cutter blade remains locked.
when you release the blade, sometimes you have to reengage it manually, turn it to unlock, machine off (safety only) push up on bottom of upper blade until it stops. turn hand wheel and watch if blade is moving. If not repeat. When it moves your good to go.
12/3/2014 8:31:42 PM •
Baby Lock...
Answered
on Dec 03, 2014
What would cause by screen to go dark on my baby long crown jewell
Could be many things, I would check the Power supply on the left of the machine when you stand in front of it. Turn off power first, then remove 4 screws power supply will come straight off. look at attached wires and make sure all are attached firmly. If that does not fix it, take it to a service man.
12/3/2014 8:14:51 PM •
Baby Lock...
Answered
on Dec 03, 2014
Automatic threader does not take the thread. I
Open the front cover and raise presser foot to release all threads. Depress the machine lock button firmly with your left index finger. At the same time manually rotate the machine hand wheel slowly forward until he button "snaps" into the locked position and the lock button release lever moves to the far left.
11/8/2014 4:08:12 AM •
Baby Lock...
Answered
on Nov 08, 2014
