20 Most Recent
Bernina Artista 180 Questions & Answers
Need owners manual
Hi there:About older manuals for Bernina Artista 170 or 180 available to download in PDF format...
Image link HERE.Try looking clicking in the previous links, we have in our database this
Instructional Book; hope this helps; also keep in mind that your feedback
is important and
I`ll appreciate your time and consideration if you leave some
testimonial comment about this answer.Thank you for using FixYa, have a nice day.
My bernina artista180 won't power on
If your Bernina Artista 180 sewing machine won't power on, here are a few things you can try:
- Check the power supply: Make sure that your sewing machine is properly plugged into a working electrical outlet. Try plugging another device into the same outlet to ensure that it's working.
- Check the cord and connections: Check the power cord for any visible damage or wear, and make sure it's securely plugged into the sewing machine. If you see any damage or wear, you may need to replace the power cord.
- Check the fuse: There may be a fuse in the power cord or on the machine that has blown. Check the owner's manual for instructions on how to replace the fuse.
- Try a different outlet: If you're using a surge protector, try plugging the sewing machine directly into a wall outlet to rule out any issues with the surge protector.
- Consult a professional: If none of the above steps resolve the issue, there may be an internal problem with the machine that requires a professional technician to diagnose and fix.
If the issue persists, it may be best to contact Bernina customer support or take your sewing machine to a certified Bernina repair shop for further assistance.
Bernina 440 stops stitching
see your local dealer and tell them you have a bad power board. or l-print. this is a known issue and bernina is covering it under there 5 year warranty. the 5 volt output is faulty on some some models
Bernina 830 won't zig zag, won't buttonhole, no decorative stitch
Basically it is a matter of a stuck part. Flip open the top by prying up on the front or ends of the lid. You already noticed the hinges on the back. When you get it open, exercise the right hand lever on top (marked ZZ at bottom and 1-20 at top. If you look just to the right of this lever against the back wall you will see that it moves a little part back and forth into triangle shaped grooves. The part is not going completely into the grooves so drop some oil in there and exercise it a few more times, using your fingers if necessary to make the part move into the triangle grooves at the front and back. After a while it will loosen up where it should operate by itself smoothly . Hope this helps, I know it will.
Why won't Bernina Artista 630 turn on?
If the machine won't power up its most likely a problem with the power board inside of the machine. I have replaced a bunch of bad power boards on the 600 and 400 series Berninas over the years. The 600 and 400 series machines use the same board. I service and sell lightly used Berninas on eBay under the user name bushvideo.
How do you adjust the tension on a Bernina 180
There are two tension adjustments, which should be done with a proper set of weight gauges - top and bottom thread tension should be carefully balanced to get the best stitch formation. It is best that you assume the top tension is correct and adjust the bobbin tension to match. Load the bobbin with thread of one colour and put a spool of the same thread but a different colour on the top. Thread-up the machine, load the bobbin and sew-off a satin-stitch on max width zig-zag. In this configuration, there should be a very small 'bead' of the top thread showing along each side of the satin-stitch on the underside of the material. If there's excessive top showing, the bobbin tension is too high and if none, the bobbin tension is too low. To adjust the tension, remove the bobbin case and you will see a spring around the edge with two screws through it. One of the screws holds the spring in place and the other adjusts the tension - this is furthest from the edge of the spring and is in a small 'cup' in the spring itself. To reduce tension, turn the screw VERY SLIGHTLY anticlockwise and to increase it turn it clockwise. Make very slight adjustments and re-check sewing-off the satin-stitch every time until you get the required thin line of top showing down each side of the stitch on the underside. Ideally this should be done with Mettler Metrosene thread, but as we're just balancing against the top tension, it shouldn't matter too much provided you use a good thread top and bottom.
My light keeps going out. If I push the power
working with Electrical parts "wires" is not something i would recommend unless you are an electrician but how ever i would try a new bulb first if that doesn't cure it i would take it back to your repair man who repaired it before
