20 Most Recent
Necchi 3537 Mechanical Sewing Machine Questions & Answers
When I press on the foot pedal the machine with sow about 2-3 sti
Usually pedals possess a variable rheostat controller that react with the action of your foot. If it fails to function normally, it suggests that a short circuit has occurred. Generally, that means an internal wire or contact opens up and stops all further activity as you mentioned. The best bet is to take the machine to your local sewing machine dealer for repairs.
My necchi sewing machine stitches too fast
A lot of machines have a speed control, either on the machine or the foot control. I looked thru the manual and did not find anything about speed control. Look under the foot control for a screw that may have a + and - . Otherwise, you may want to take it back to see if service can adjust it for you.
Making a buttonhole on a Necchi 3204 sewing machine
Here's what the manual says:
Before sewing, fit the button-hold foot to the machine (long white plastic thing with red, ruler like markings).
Select the pattern selector dial that is solid green on the left hand side. Set the dial to "1" position. Sew the left side and raise the needle.
Select the pattern selector dial that is solid green on the top and bottom. Set the dial to "2" position. Sew 5-6 stitches and raise the needle.
Select the pattern selector dial that is solid green on the right hand side. Set the dial to "3" position. Sew the right side. Raise the needle.
Select the pattern selector dial that is solid green on the top and bottom. Set the dial to "4" position. Sew 5-6 stitches and raise the needle.
Hope that helps...
Necchi sewing machine
There are a number of things that could cause this.
Needle installed with flat in the wrong direction.
Excessive thread tension,top or bottom.
Lack of lubrication. If the machine can do anything more than a straight stitch the mechanism can gum up and not move the needle correctly.
Here is a link to threading directions.
Necchi 3537 Sewing Machine Threading Diagram
