20 Most Recent
Batteries.com 2-Way Radio Battery for Kenwood Questions & Answers
Need discontenued tel patch plug for kenwood tr-9000 part # E09-0471-05
Hi David,I'm not sure of what this part is, but Kenwood is a very good Make, so I suggest the following: join yahoo group Specific to your radio Make & Model No., the team there will require as much info from you as possible, so they can help you, you can also download manuals, diagrams and other goodies for your radio(if available), and all this is free.I hope this has helped you and good luck with the plug.Cheers,Peter
Looking for tilt handle for kenwood r1000
- Discontinued part # N08-0601-05 SCREW,HANDLE R-1000 . At the link it will be #18 down the list. Kenwoods contact information is at the top of that page as well.
- If you have any comments please feel free to leave them here and i will respond to you.
- Hope this helps and thank you for using FixYa,
Regards,
Tony
How to wire a fridge thermostat
Wiring a fridge thermostat typically involves connecting the thermostat to the power source and the compressor. Here's a general guide for wiring a 3-pin thermostat:
- Identify the Pins: The thermostat will typically have three pins labeled 4, 6, and 3.
- Connect the Power Source: Pin 4 is usually the common (C) terminal, which connects to the power source. This could be the live wire from your electrical supply.
- Connect the Compressor: Pin 6 is often the normally open (NO) terminal, which connects to the compressor. This allows power to flow to the compressor when the temperature rises above the set threshold.
- Ground Connection: Pin 3 is commonly the ground (GND) terminal. This should be connected to the ground wire for safety purposes.
4/19/2024 7:20:26 AM •
Radio...
Answered
on Apr 19, 2024
Realistic scanner police codes
I recommend RadioReference.com, they have detailed lists from all over the United States. In addition to frequency lists, they also include live audio, HAM radio lists, licensing information and a lot more.
4/4/2024 5:32:44 AM •
Radio...
Answered
on Apr 04, 2024
Serial Number for KPG-790
All questions need FULL 'make model (what it is) first 3 words please.
Something to do with this? The serial number should on the label on the rear by the mains cable. This is a statutory requirement unless someone removed it to hide its identity.
https://www.google.com/search?q=KPG-790
2/15/2024 3:06:45 AM •
Radio...
Answered
on Feb 15, 2024
